1 title failed
enigmoo
1 title failed
Post by enigmoo » Tue Feb 02, 2010 11:17 pm
1 out of 7 titles failed in 1.4.12 x64 on Win7. Please see attached log file. Appreciate any help to resolve. Thx!
setarip_old
Re: 1 title failed
Post by setarip_old » Wed Feb 03, 2010 3:01 am
Hi!
Actually it looks like all titles either failed or were less than 120 seconds in duration.
It also looks as if your drive may be faltering.
What is the title and Region of your original BluRay disc?
enigmoo
Re: 1 title failed
Post by enigmoo » Wed Feb 03, 2010 4:51 am
setarip_old wrote:Actually it looks like all titles either failed or were less than 120 seconds in duration.
There are 7 main titles, but I had only the failing title selected for this extract. All other six titles extracted fine.
setarip_old wrote:It also looks as if your drive may be faltering.
If you are referring to the msgs "Program reads data faster than it can write to disk", in my system it is truly the case that my HDD is the bottleneck and this is an I/O-intensive operation. The drive is healthy, though, as I have run SpinRite regularly.
setarip_old wrote:What is the title and Region of your original BluRay disc?
Pushing Daisies TV Series, region A. First season has 2 disks, 9 episodes, and it went fine, without a hitch. This is the second season, the 1st of the 2 disks, episode 6 of 7 that is failing.
Thx for your help!
Re: 1 title failed
Post by mike admin » Wed Feb 03, 2010 8:39 am
What program did you use to decrypt the disc in a first place? It looks like some areas of M2TS files are decrypted incorrectly.
enigmoo
Re: 1 title failed
Post by enigmoo » Wed Feb 03, 2010 12:36 pm
DVDFab 6.2.1.8.
Re: 1 title failed
Post by mike admin » Thu Feb 04, 2010 7:19 am
enigmoo wrote:DVDFab 6.2.1.8.
The only way to confirm is by trying to open original disc, not copied files or iso. Can you please try to open the same title from the physical drive and see what happens?
enigmoo
Re: 1 title failed
Post by enigmoo » Thu Feb 04, 2010 2:47 pm
mike admin wrote:Can you please try to open the same title from the physical drive and see what happens?
If I run MakeMkv directly against the disc, then this title extracts and plays fine. I guess we redirect the finger-pointing to DVDFab :wink: Thx for your help!
