At least when you have a rich source to start with the results are worth it.
setarip_old wrote:@TexasGrillChef
Hi!
If you've got a BIG bloody rare porterhouse on the grill for me, thanks to fellowmember "Justin Chase", I'll share the secret with you - the secret being how to get viewable PGS subtitles in an MKV container WITHOUT having to bother with OCR ;>}
It's not really a secret, if you're a careful reader (Seems to me I've mentioned this to you at one or two forums before)
Carefully read the following earlier posts to this thread by me and "Justin Chase":
Start with my post dated 1/21/10 and read through and including the 1/24/10 post by "Justin Chase".
To summarize:
1) Use the newly available "MKVCleaver" to automatically extract the PGS subtitle stream as a .SUP file.
2) Load the .SUP file into "BD Sup2Sub"
3) Save as "SUB/IDX"
4) Load original MKV into "MKVMerge" GUI ("mmg.exe")
5) "ADD" "SUB" file ("IDX" file will be rejected - not needed anyway)
6) "MOVE" "SUB" file up until it is one position higher than the matching PGS file (So that it precedes the PGS file when reading from the top down)
7) Set an output filename and location and click on the "Start muxing" radiobutton.
And that's all she wrote ;>}
And because I have a sense of with whom I'm dealing:
Step 1 = 5-10 minutes (Depending on system)
Steps 2-6 combined = How fast can you type? One to two minutes for input, with one hand tie behind your back
Step 7 = 10-15 minutes
Mmmmm, smells like that steak is just about ready ;>}
(Let me know how things go)
Your post that I responded to says NOTHING about needs related to specific equipment.My LG BD390 needs SRT subtitle files as seperate files in the same directory with the same name for it to work their.
