Tried creating mkv on mac os x....failed.
"002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '0'
A lot of the above. I had been reading a bit to see if it was a SVQ problem but this isnt is it? Please advise, I would love to buy this product if it can rip blu rays for me. I am trying to back up what I have already. Thanks!
Debug log started at Tue Oct 15 21:57:00 2013 , written by MakeMKV v1.8.5 darwin(x86-release)
001005:0000 MakeMKV v1.8.5 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/devinmichaud/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BE14NU40 1.00d" opened in OS access mode.
005050:0000 Evaluation version, 0 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=VTvbupJtjz8m65JE729bCh4Ndq4DpWysZXTnEyzksB4lU1sjvD4TxOc812tJXg2YJWyrWJGxc8wicl5tqejgrbzrq/Hp8I52RiQ+1Raqy87zbVlWqr/4x5xl3GdeBgRYStR4prsAL/mPyzlqjyV8nqF2G6fwtvV9Hg==
DCE=uXXr2tF36gSanSRaURk6F5VR3GmmsZdrV/258tj4iYUdjuxkT+fyIo9tRa9v1xuGXSgwxPeO4TyDZmet8+N5q1BP0UV2Lhv+a4XP6GHzq4l/2TCHhO65JBVGl4GwN0MDbe1MlYCU0XcziB36tjZPJLjWc2BIAtl2yg==
003317:0000 Loaded 37 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
001003:0020 DEBUG: Code 0 at re(L.EFG$ylO82L,m=:121267454
001003:0020 DEBUG: Code 2 at e]hsRwVfD'0ywxK|1%:213135987
001003:0020 DEBUG: Code 0 at e]hsRwVfD'0ywxK|1%:121264372
001003:0020 DEBUG: Code 3 at e]hsRwVfD'0ywxK|1%:213135987
003332:0000 Saved BD+ dump file as /Users/devinmichaud/.MakeMKV/dump_The_Tree_of_Life_D70B76F4D2890438.tgz
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=D70B76F4D289043807B5DBDDD3821807961E72DC
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00851.mpls was added as title #1
003307:0000 File 00405.mpls was added as title #2
003309:0000 Title 00800.mpls is equal to title 00851.mpls and was skipped
003307:0000 File 00003.mpls was added as title #3
003309:0000 Title 00850.mpls is equal to title 00851.mpls and was skipped
003307:0000 File 00720.mpls was added as title #4
003307:0000 File 00004.mpls was added as title #5
003309:0000 Title 00801.mpls is equal to title 00851.mpls and was skipped
003307:0000 File 00007.m2ts was added as title #6
003307:0000 File 00009.m2ts was added as title #7
003307:0000 File 00005.m2ts was added as title #8
003307:0000 File 00006.m2ts was added as title #9
003307:0000 File 00008.m2ts was added as title #10
005014:0000 Saving 11 titles into directory /Users/devinmichaud/Desktop/Test
AV sync issues in /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t00.mkv
AV sync in 1 at 0:00:38.288 (15.75ms) : encountered overlapping frame, audio skew is +15.75ms
AV sync issues in /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t01.mkv
AV sync in 1 at 0:00:00.004 (10.666ms) : 1 early frame(s) dropped at start
001003:0020 DEBUG: Code 1073741829 at &F%UL/UF/SJ3N4V$:29393953
001003:0020 DEBUG: Code 4 at IeKUO/OGgQqV`&o':213137827
001003:0020 DEBUG: Code 268435459 at z~B.DG[[70`'lN?PUN#!m@gc'xi:213130950
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '18457165824'
001003:0020 DEBUG: Code 1073741830 at &F%UL/UF/SJ3N4V$:29393953
001003:0020 DEBUG: Code 0 at x(itRX-Wm:+J~"&KA$k8:121262739
001003:0020 DEBUG: Code 0 at J>R?9%!n.N;P^8M%-&Pc:121261888
001003:0020 DEBUG: Code 0 at x(itRX-Wm:+J~"&KA$k8:213130743
001003:0020 DEBUG: Code 9012288 at x(itRX-Wm:+J~"&KA$k8:29393332
001003:0020 DEBUG: Code 0 at :[}mi-}:cvnlj\.}R{|@Y:29398645
005003:0000 Failed to save title 1 to file /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t01.mkv
001003:0020 DEBUG: Code 0 at ItTnkI=\n*F^H_cwA:213133503
001003:0020 DEBUG: Code 1073741830 at `#ukxgP{q94b@F#a:213139920
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '0'
001003:0020 DEBUG: Code 0 at J>R?9%!n.N;P^8M%-&Pc:29396483
001003:0020 DEBUG: Code 0 at x(itRX-Wm:+J~"&KA$k8:213129915
001003:0020 DEBUG: Code 0 at x(itRX-Wm:+J~"&KA$k8:213130099
001003:0020 DEBUG: Code 0 at x(itRX-Wm:+J~"&KA$k8:29393332
001003:0020 DEBUG: Code 0 at :[}mi-}:cvnlj\.}R{|@Y:29398369
001003:0020 DEBUG: Code 0 at :[}mi-}:cvnlj\.}R{|@Y:121266925
001003:0020 DEBUG: Code 0 at kA}R)0*:HiA{&e<InX}3:121270927
001003:0020 DEBUG: Code 0 at *~BVofbTWvxn<+uB:29393930
001003:0020 DEBUG: Code 0 at '>WD)hq&S}fl?"k@bX:213135067
001003:0020 DEBUG: Code 0 at '>WD)hq&S}fl?"k@bX:213135481
005003:0000 Failed to save title 2 to file /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t02.mkv
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '0'
005003:0000 Failed to save title 3 to file /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t03.mkv
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00720.m2ts' at offset '0'
005003:0000 Failed to save title 4 to file /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t04.mkv
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '0'
005003:0000 Failed to save title 5 to file /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t05.mkv
005003:0000 Failed to save title 6 to file /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t06.mkv
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '0'
005003:0000 Failed to save title 7 to file /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t07.mkv
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '0'
005003:0000 Failed to save title 8 to file /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t08.mkv
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '0'
005003:0000 Failed to save title 9 to file /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t09.mkv
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '0'
005003:0000 Failed to save title 10 to file /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t10.mkv
005004:0080 1 titles saved, 10 failed
005037:0204 Copy complete. 1 titles saved, 10 failed.
001003:0020 DEBUG: Code 2281701379 at IeKUO/OGgQqV`&o':213134699
Tree of Life Blu Ray
Re: Tree of Life Blu Ray
Is this a USB powered drive?
Make sure you have sufficient power; plug it into a POWERED hub (rather than directly into the Mac), and use the second USB plug if your drive came with a dual-head USB cable.
Many times, when a port-powered drive kicks into higher speeds, the USB power from a single USB port is not enough, so it goes off-line. Ooops. But the error message for when this happens sucks big time.
I've seen it happen when people print during rips... and the printer draws just enough power to take the drives off line.
dmichaud
It is an external usb drive by LG. Its only got one USB 3 port. IS that ok?
So Youre saying to try a standard USB hub, and run the drive to that, and the hub to my laptop? That it? Ill run out right now and get one. I just want to get this working, its been driving me mad. Seems like I can rip about one out of every 5-6 BR I try.
dmichaud
Well after reading a forum, I switched to a USB 2.0 cable and got this. Onto the USB hub.
Debug log started at Tue Oct 15 23:59:17 2013 , written by MakeMKV v1.8.5 darwin(x86-release)
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DCE=A57QfeDLq/LTE7vPT6dNPSeqE54gqRi/Bhx7qg7QGK7XZ07X9VX4fAM3W91lxxkcFz2/FT5PW0O8ckpW/im0mrR3RLQTP/07zw3+tx/CSMm5Nfmc0YSdVAd/eD1P+RmXePnQI3qYxp7xyTNUhg/9oG5eJWqHQvFnGQ==
DCE=A3jRzAVDOAdq0TP9US1wsu5rV2D8cF0rS+oFHPj2ZO4v3A291a7gHAKowHlCdvtup82PE5w9ZZYY+lcU3Uh/eF0wJE2Mv2TEExbv8R9dYkCutO+Wi4nQwhuSxaQMyGAz3c1QtSNiKolPC0cXd8/idOLLco4LpofKZw==
001003:0020 DEBUG: Code 233 at 4yJpivFVnZBO5nyit4KruxJ3:0
001003:0020 DEBUG: Code 233 at zWWOKlLnvEMRH3Y4mK7psp+C:0
001003:0020 DEBUG: Code 233 at fkcRlI9pMHVZo92+O+fG4/Eu:0
001003:0020 DEBUG: Code 233 at ISJ86lIwXtleaCGcyDjN/XMS:0
001003:0020 DEBUG: Code 2 at IeKUO/OGgQqV`&o':213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '10273241088'
001003:0020 DEBUG: Code 5016231 at x(itRX-Wm:+J~"&KA$k8:29393332
AV sync issues in /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t03.mkv
AV sync in 1 at 0:00:00.001 (32ms) : 1 early frame(s) dropped at start
AV sync issues in /Users/devinmichaud/Desktop/Test/The_Tree_of_Life_t09.mkv
AV sync in 1 at 0:00:00.001 (10.666ms) : 1 early frame(s) dropped at start
005004:0080 10 titles saved, 1 failed
005037:0204 Copy complete. 10 titles saved, 1 failed.
This is "just" a read error. Your drive can't read the disc - either a scratched disc or failing drive.dmichaud wrote:002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '10273241088'
