libaacs & libbdplus support for xbmc
will the same method that should work for vlc also work for xbmc? I remember seeing a suggestion a while back for implementing this.
- Contact:
Re: libaacs & libbdplus support for xbmc
Yes, but blu-ray support in xbmc is rather limited. Any software based on libbluray will work this way.
The non existing support of menues et al is really a pitty. but its just about the waf
if she can pop in a kids movie and easly play the main movie its completly cool. using the makemkv plugin was a bit tricky till now.
