Clone Wars season 5 error DEBUG: Code 68 at aQz@ofj}|gB~qlTc
Tsunamijhoe
Post by Tsunamijhoe »
Hello
When trying to rip individual episodes i get this error from bluray disc 2.
DEBUG: Code 68 at aQz@ofj}|gB~qlTc:c}Y3:213132997
What does it mean? Is the ripped episodes ok?
Thank you
Re: Clone Wars season 5 error DEBUG: Code 68 at aQz@ofj}|gB~
Debug codes generally mean MakeMKV encountered something weird, and tried to work around it. If it later says the title was saved, the work-around was successful, and the title is probably just fine.
If it says the title wasn't saved, then you should post the debug logs, so that Mike can look at them. Link on how that is done is in my signature.
Tsunamijhoe
Thank you, i guess the episodes are ok then,as all was saved,and all seem to be the correct size and everything
