I'm delighted with my full version of MakeMKV. My only rip failure thus far is the same as as morsfar reported on 31 Mar 2012 for Sex and the City. Seasons 2 to 6 rip fine but with Season 1 the rip only shows only Title 8 for disc 1 and only Title 8 for disc 2. I'm using MakeMKV version 1.8.4.
The log extract for disc 1:
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
CellTrim algorithm failed since title has only 1 chapters
Title #3 (0:26:13) was skipped due to navigation error
Title #4 (0:24:39) was skipped due to navigation error
Title #5 (0:23:17) was skipped due to navigation error
Title #6 (0:23:05) was skipped due to navigation error
Title #7 (0:24:29) was skipped due to navigation error
Title #8 was added (1 cell(s), 0:23:07)
The log extract for disc 2:
Title #3 (0:24:09) was skipped due to navigation error
Title #4 (0:24:00) was skipped due to navigation error
Title #5 (0:23:03) was skipped due to navigation error
Title #6 (0:22:59) was skipped due to navigation error
Title #7 (0:25:03) was skipped due to navigation error
Title #8 was added (1 cell(s), 0:26:18)
I tried to add the ifo files to this report but received the message 'The extension ifo is not allowed'.
Thanks in advance for your help!
MakeMKV and Sex and the City Season 1 problem
- Contact:
Re: MakeMKV and Sex and the City Season 1 problem
Please enable "log debug messages" and post the full log (saved by MakeMKV, not copied from lower pane).
MakeMKV_log.txt (for both DVDs) attached as requested.
- MakeMKV_log.txt
- (6.81 KiB) Downloaded 572 times
I've downloaded and used new version 1.8.5 but still only getting 1 episode so have attached the new log in the hope that it helps. Thanks in anticipation of your efforts on this and looking forward to completing the digitisation of season 1 to complete my collection.mike admin wrote:Please enable "log debug messages" and post the full log (saved by MakeMKV, not copied from lower pane).
- MakeMKV_log.txt
- (3.56 KiB) Downloaded 535 times
Hi I was wondering if a solution has been found for this problem and, if so, how I access it? Thanks.
I'm having the same problem. Has anyone been able to backup Sex and the City season 1?
I'm afraid not yet dejones. I had a message saying it had been 'overlooked' and they'd work on it soon ... so I live in hope!dejones wrote:I'm having the same problem. Has anyone been able to backup Sex and the City season 1?
- Contact:
Will be fixed in the next version, should be ready in a few days. Thanks a lot for sending IFO files for both discs.
I've upgraded my version of MakeMKV to MakeMKV 1.8.6 for Mac OS X. I tried to make a backup of the Sex and the City season 1. But it doesn't open the disc. I tried to open some other DVDs I own and they won't open either.
Daniel
Daniel
Thanks, v1.8.6 works a treat and now I have the complete collection in digital!mike admin wrote:Will be fixed in the next version, should be ready in a few days. Thanks a lot for sending IFO files for both discs.
