Fatal Error occurred, programm will now exit
Using Ubuntu 9.10.
Installed according to
http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224
Once I try and run makemkv, I get this.
Any ideas?
I'm a beginner in lunix...
Any ideas?
driver140771
Re: Fatal Error occurred, programm will now exit
I think, we have the same problem.
http://www.makemkv.com/forum2/viewtopic.php?f=3&t=944
Please, look to
/var/log/message
for errors.
Please, look to
/var/log/message
for errors.
Correct,
in /var/log/messages
I see
[ 3587.315895] makemkvcon[2050]: segfault at 0 ip 08227360 sp 982f7ed8 error 4 in makemkvcon[8048000+3c3000]
I see
I get the same
starting makemkvcon from dash works though still arrives at segfault
Feb 2 17:42:03 Skittle-PC kernel: [ 5810.030953] makemkvcon[6444]: segfault at 0 ip 000000000060398e sp 00007fe20cbc3ba0 error 4 in makemkvcon[400000+48c000]
- Contact:
is this in 1.4.11 or 1.4.12 ? can you provide the core dump? please send it to support@makemkv.com in case it contains any private information.
Thanks,
I am kind of new, how do I get the core dump? The version is the newest one, 1.4.12
driver140771
driver140771
i have only this information:
vdr@vdr-pc:~$ sudo /usr/bin/makemkvcon info
001005:0000 MakeMKV v1.4.12 beta linux(x64-release) started
Segmentation fault
vdr@vdr-pc:~$ -
JackieBrown
Same error on Debian 64 using 1.4.12
Going back to 1.4.11 fixed the problem
1.4.11 worked for me as well. Thanks.
By the way, in the future, how do I remove makemkv if I want to?
driver140771
I don't have the Vesion 1.4.11
I also hope the Version 1.4.12 (13) is working soon.
Thank's
Thank's
shemsha:
mikeadmin: I have created a coredump for you, and sent it to support@makemkv.com
Others: to make a coredump, to then run the program.
sudo rm /usr/bin/makemkv & rm /usr/bin/makemkvconOthers: to make a coredump, to
ulimit -c unlimited-
JackieBrown
Mike - I am linking 1.4.11. If you need me to remove it, just let me know.
I made no edits to the tars you originally uploaded
http://www.mediafire.com/file/uyzld5ymm ... bin.tar.gz
http://www.mediafire.com/file/dmtufztto ... oss.tar.gz
phantasm4489
I tried to install this program last night and had the same problem with 1.4.12. (segmentation fault on startup)
I downloaded 1.4.11 instead (by altering the urls in the official link to 1.4.12) and installed that and it works fine.
