New Key?
Re: New Key?
The new key will be for all versions, and it will be posted in the Announcements section. Look for the message that has the subject, "MakeMKV is free during beta". The date on the message never changes, but the contents are changed with each new key.
rjbell4
Re: New Key?
I went ahead and finally just paid for a MakeMKV license. I've ripped dozens of discs at this point, and very much value being able to access my BluRay library digitally, and doing the ripping on Linux, so I figured I might as well use the opportunity to support the author.
dwaynnyt
Re: New Key?
Very nice. I was looking for a Linux flavor to use. Which one are you currently using if I may ask.
