pop up - trial period expired
johnnyj
I am new to this - I downloaded the free trial but waited to try it - am I now out of luck? I will purchase the permanent key if I am satisfied with product. Do I need to enter the beta key for my trial - if so, are there instructions how to do this?
crowfax
Re: pop up - trial period expired
johnnyj
Thanks - are there step by step instructions how to enter the beta key?
crowfax
Help -> Register -> [Enter the code from above]
whytewaterlover
I'm the same boat. How do I get a key or password. When it worked it was the bomb
whytewaterlover
got the code. now where to put it?
Smithcraft
crowfax wrote:Help -> Register -> [Enter the code from above]
thedigitalhobo
I presume there will be a new beta key for October?
I'm guessing the message is popping up b/c it is the end of Sept.
If not, then I'm happy to buy a key as MakeMKV is a tremendous proggy!
