MakeMKV never brings up settings tree for audio and subtitle
eindietmar
Post by eindietmar »
hi
I hope anybody has a solution for this.
i try to rio a blue ray and alwas experience the same problem. After Opening the blueray it just stays on that screen and starts doing a 1:1 copy of the blue ray to my hdd. There are never ever any settings for audio or subtitles nor does it allow me to do an mkv file.
anybody?:)
Help is much appreciated!
cheers dietmar
Re: MakeMKV never brings up settings tree for audio and subt
Which button are you clicking on?
There should be a big one with a disk on it, which defaults to creating the list of titles ("opening" the disk), after which you select which titles you want to turn into MKV files, and any options you want to use.
There is also a smaller "backup" button that will do what you report.
