Starting to wonder if my drive is dirty. Seem to need to try 2-3 times before getting through a disc successfully.
This was my latest attempt to back up a brand new disc.
Here's a snippet of the log. Full log attached.
Debug log started at Thu Sep 26 12:37:24 2013 , written by MakeMKV v1.8.5 win(x64-release)
001005:0000 MakeMKV v1.8.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\XXXXX/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEFgACATRPNTA0MTkgAQkAAAEKAAw=
DCE=5UjcekDXYBVNn/En+fHtZKNztxNyIY7U2S3ymrwRd+sCSPRKvX7fqqySAVtqvzcLuyw12gZF336aU5Qv8soUkSFWtfLMXPyDORpm90nw3bCIsrjKEuq/sxmvQi20TkPFFBnsm5/iy0tFLxVmR94xCSoGanU6wqEmnw==
DCE=CsTW/cqVswLcEMJeACGs9PMPw6oQUXtvA6R7f+dRyv4kFApu4NBHjVKMtHsOYWzGcTocT9oaKSNJFN7Ib0JH4qFHKOE6N0mINs2tKZEZdJ7Wd118ZkUS/5okzOTc6QcZ0IJSQ1UHqy4eWiRq0rEN5fxu2lCqjahL0Q==
DISCID=20C86A6BF0A5E5D76D1E21B203845F39E5D4FCBA
003025:0000 Title #00010.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00100.mpls was added as title #0
003307:0000 File 00004.m2ts was added as title #1
003025:0000 Title #00012.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00069.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory D:/
tp=PNgv5H3nTC5TcP0BS4TUYrs38UChJMkrVHptzZfSlqQrvBgCzILDSN6bffHiNn/gXryuLEC8RYGk3LAURxbzJuxBO5iV3O9kB8zH0E345iN7tueHI48//eJ+2JJ39TxYQvprAYDiTLRzpJGDYrbMEEnU25YVA6/EbJ83HVUskdnJQYYMxcRjaIxQ0srs3vKIN8YRVu9grAfPu1Wy19JI5rloh28yqtQzjfGprlotuA1OavAd/7O2oMfLrqao=
001003:0020 DEBUG: Code 0 at <:[}Wfm2Jp0@X.X_ML"I:29394574
tp=PqLCSDzYL+R950wuU3D9AUuE1GK7N/FAoSTJK1R6bc2X0pakK7wYAsyCw0jem33x4jZ/4F68rixAvEWBpNywFEcW8ybsQTuYldzvZAfMx9BN+OYje7bnhyOPP/3iftiSd/U8WEL6awGA4ky0c6SRg2K2zBBJ1NuWFQOvxGyfNx1VLJHZyUGGDMXEY2iMUNLK7N7yiDfGEVbvYKwHz7tVstfSSOa5aIdvMqrUM43xqa5aLbgNTmrwHf+ztqDHy66mq
004004:0000 The source file '/BDMV/STREAM/00031.m2ts' is corrupt or invalid at offset 12886536192, attempting to work around
tp=PSbxxWCjHYwAHEHj1Hy7Xvij5m8YcDATx7ijnN8dIqzsYFTrDyIi87wAnY1PpeE48w2Z/M0NTOqau8wKf+Sl2X2KfuU0wT4JWw05JzoX1s4Z2TRawnEB8HxvEIStOpDup9QuH9u/WQyUOjti0KMOz7jhvY7DFIX1+SGoXsjZtI8aLrrzSIAN7ihFYFodHVmYsYgYSZzNEX7YuzQkCIsLc1IrqlPZLNoa4wQN7DPZHuHObkK09bXsi2Li+X0Q=
tp=PUw+bEEHwgZ7OqQOxoID3IVsVT9EA5gonnlZIHgBurikhZsTXS7OaJeHBqwa32bN7w98R8w9TF0It9xkyNtB1hBtycpjFU+vxhyRgnXIAJ7rH7NVxg6ci+rKPdb58aJFPYKw8OCDRxH7hHWW8GDNV05g5nUJ4J+8tzavNdOycnMN+9uIRC9cmV7GI468qjrpnzTFo/TmpYtiKQQ6yzp9mOm/irv0HbSeVebZo+RODZ7qJzQh3Gdm42+usJxs=
tp=PL2mxbFMPmxBB8IGezqkDsaCA9yFbFU/RAOYKJ55WSB4Abq4pIWbE10uzmiXhwasGt9mze8PfEfMPUxdCLfcZMjbQdYQbcnKYxVPr8YckYJ1yACe6x+zVcYOnIvqyj3W+fGiRT2CsPDgg0cR+4R1lvBgzVdOYOZ1CeCfvLc2rzXTsnJzDfvbiEQvXJlexiOOvKo66Z80xaP05qWLYikEOss6fZjpv4q79B20nlXm2aPkTg2e6ic0IdxnZuNvrrCcb
004004:0000 The source file '/BDMV/STREAM/00031.m2ts' is corrupt or invalid at offset 12886542336, attempting to work around
tp=P4vTOgu2S+j3aWNTvFQUZeEHaZoqo2um6LYdDj3jY3qE3s81FuX7ghMKMz1SFdsnAVvNFhpGiIvMbEstYLij69pOp+enx+5Wp69joLUS04S2oPqjcpxTbf8q8PfFOWMx+GaL4Uw/DGRK4pHJZ5aZg+EA2L7xmuO0w7K9Cu3Q2jOrl2WKscTnUIPzgaSMWjfxx3sN7uKigjMBlTiRv6VBOjEghtBhkvZvyPkh1PlXCsP3zEv6znHuqvgZlQ9M=
tp=PMzXTfuL0zoLtkvo92ljU7xUFGXhB2maKqNrpui2HQ4942N6hN7PNRbl+4ITCjM9UhXbJwFbzRYaRoiLzGxLLWC4o+vaTqfnp8fuVqevY6C1EtOEtqD6o3KcU23/KvD3xTljMfhmi+FMPwxkSuKRyWeWmYPhANi+8ZrjtMOyvQrt0Nozq5dlirHE51CD84GkjFo38cd7De7iooIzAZU4kb+lQToxIIbQYZL2b8j5IdT5VwrD98xL+s5x7qr4GZUPT
tp=Pu3DWnBHe04co8SSKMDaWDIVovQwuzbyaIPhojFCZjQ5zrNQwfoJlkhmUEq5wOOSJMTMmN3nCpRGeVoAvfCTrkd6Bvv1VpI9OEZR20Tt2r7T3tfSZAFWkPdWS6/c60BqqWnkwYebU1BTGBZoBdk3hTjzztznjmkttHyafm3odBIx/Hw1TppPZslDcIkL/VzQAhIdq7UtEQEaTeKBvt0wIlL4yi0mEClieXqwoBRpPaVviuGMN782E5pw9Qm0=
tp=P8J48wbtw1pwR3tOHKPEkijA2lgyFaL0MLs28miD4aIxQmY0Oc6zUMH6CZZIZlBKucDjkiTEzJjd5wqURnlaAL3wk65Hegb79VaSPThGUdtE7dq+097X0mQBVpD3Vkuv3OtAaqlp5MGHm1NQUxgWaAXZN4U4887c545pLbR8mn5t6HQSMfx8NU6aT2bJQ3CJC/1c0AISHau1LREBGk3igb7dMCJS+MotJhApYnl6sKAUaT2lb4rhjDe/NhOacPUJt
tp=PuyEQ1SmhpBlpZsoaBBL1Sl2Yb8jEe2lXGsMdM2mzS55QwPc3tA1GnNvqTrNRxzPBAaSWHimnkS4GT8SZg2MXj0wKXwrKdDW6GACJZ96aOpz67lZrrHPU9yvf1QPdswJGU6GtOgn1cz+IZeWuJ975AYF3C9LR7LfWKL4xsxALAYMk+3YnIvLLkUl8KaPC1A/veljclwhyZxagMtW0zNpIHAxtn26LCVjfaQrt6/dcn07Y9qSW7oFqhaU6Fgs=
tp=PbInJrLshENUpoaQZaWbKGgQS9UpdmG/IxHtpVxrDHTNps0ueUMD3N7QNRpzb6k6zUcczwQGklh4pp5EuBk/EmYNjF49MCl8KynQ1uhgAiWfemjqc+u5Wa6xz1Pcr39UD3bMCRlOhrToJ9XM/iGXlrife+QGBdwvS0ey31ii+MbMQCwGDJPt2JyLyy5FJfCmjwtQP73pY3JcIcmcWoDLVtMzaSBwMbZ9uiwlY32kK7ev3XJ9O2Paklu6BaoWlOhYL
tp=PUpsM0m/7spbQeXwW78eDeMbmwBvdC+p8zCgeoxBnW37HyqtnN/izHVYUJGt4cNKmBWcPCScaJbbuHtwtVN4LEthN0JQ8DNQS1olRQhKYwcE9Vr+SRPTmA52ktFvF1si2dKGQM5fbbHXp/wv5FLPuJY6hPhgVj50FljqeFzvEF2u7h83XYdKIcVweco0ARIG+r9vvPngHTvHmDPzO39lKrwkPq3YGTVaqw3CHaoiTEmT2hWiwyF3bh88Y5w4=
tp=PW/cRTFKbDNJv+7KW0Hl8Fu/Hg3jG5sAb3QvqfMwoHqMQZ1t+x8qrZzf4sx1WFCRreHDSpgVnDwknGiW27h7cLVTeCxLYTdCUPAzUEtaJUUISmMHBPVa/kkT05gOdpLRbxdbItnShkDOX22x16f8L+RSz7iWOoT4YFY+dBZY6nhc7xBdru4fN12HSiHFcHnKNAESBvq/b7z54B07x5gz8zt/ZSq8JD6t2Bk1WqsNwh2qIkxJk9oVosMhd24fPGOcO
tp=PKtkFnBT6YsggJYCHPUFnacwmH5H6zQQDfiqsPOc4/dH6fTo9fp9mzcp25D+PYebI2HcD2eIiU4pixKS0XyxU63C4SneIkRTHAnBFnKC4zufJvcZW63+/wp1gOAqjTUdVeAoBysU5agqz9pPjhjRNzja8cdye07FHC+ix547U0FwzXclPj7xXXQWf1afLz7O8V67haqx44SSqdFcElss6V1JAA54SfjMo8WzbNnwpgTffWdXGR1SF6UNDgOQ=
tp=PsionoCrZBZwU+mLIICWAhz1BZ2nMJh+R+s0EA34qrDznOP3R+n06PX6fZs3KduQ/j2HmyNh3A9niIlOKYsSktF8sVOtwuEp3iJEUxwJwRZyguM7nyb3GVut/v8KdYDgKo01HVXgKAcrFOWoKs/aT44Y0Tc42vHHcntOxRwvoseeO1NBcM13JT4+8V10Fn9Wny8+zvFeu4WqseOEkqnRXBJbLOldSQAOeEn4zKPFs2zZ8KYE331nVxkdUhelDQ4Dk
tp=PbxrM6WFoyEx88ciMi8F/8RM6xCrV89EcoMKgDrF0DHRd2ryYC5OjBtHxA5kIGSE3DflRKFjbnwk8C3vpMHIB1cYLZusSkEYke1DBGmC0hk1W/9xHbhdqopdrLJgokW7zPjQJd/WK7kw5XludvWmQ4V+Ya0BGP/EoHdsAocYLoZq29Pu+jafv+PE9Z7sC28WV1BsxUNPipPpOtMblgsGfcsqKmsVfMZkkpt0ESD7L7Rw8IOOCI9X31opQE5k=
tp=Py8N40G8azOlhaMhMfPHIjIvBf/ETOsQq1fPRHKDCoA6xdAx0Xdq8mAuTowbR8QOZCBkhNw35UShY258JPAt76TByAdXGC2brEpBGJHtQwRpgtIZNVv/cR24XaqKXayyYKJFu8z40CXf1iu5MOV5bnb1pkOFfmGtARj/xKB3bAKHGC6GatvT7vo2n7/jxPWe7AtvFldQbMVDT4qT6TrTG5YLBn3LKiprFXzGZJKbdBEg+y+0cPCDjgiPV99aKUBOZ
tp=PSPdPqDjgZmwxu7qZQHQAWzKKDdrRbw7HO5k/qaFccKGFFS/YsGc0F0M+SdGI0DJ1zMaA/lV/DyfeOnySnbTI3FUMNLGunsLr57cYolo9MDwK5yQSWFg/CWyb5FgWGjUfgCYCz9LStlgHBFp0Po1Jqnx29uIi7xzLWrLhUP9jggJHEBEQ7UuzM2hI2fZdAWh+uDhwHRlj7b3YQmXqok+BXyooQGfIKiTjtT/JdlRFDiwMe/2a/aCIvT+JwDo=
tp=PCSqIYUj3T6g44GZsMbu6mUB0AFsyig3a0W8OxzuZP6mhXHChhRUv2LBnNBdDPknRiNAydczGgP5Vfw8n3jp8kp20yNxVDDSxrp7C6+e3GKJaPTA8CuckElhYPwlsm+RYFho1H4AmAs/S0rZYBwRadD6NSap8dvbiIu8cy1qy4VD/Y4ICRxAREO1LszNoSNn2XQFofrg4cB0ZY+292EJl6qJPgV8qKEBnyCok47U/yXZURQ4sDHv9mv2giL0/icA6
tp=PEd9q4Izx5dNKQTfrl7m78mpb1jWNjVo9Mq+DTj4rMW9gdedOojN+dPbi60QN/Esj7L/oqu6zyy/tzToYc0G1fjjShnjxdiXRxH6iVVJP4rxOEy0LjuuiCw6RjSxODrieBZt8P1HYTzpJbXjqGDkmbYfTPbKEGtnIXZPRYTFUyEIgev19hMtxLm9hmcv4DH0WCiesgY2ITEwiQikt+IbU6tcj1j7/FUoevjkSTIlqsEnLhOdplQwBSeq5M68=
tp=PBUS7tRHfauCM8eXTSkE365e5u/JqW9Y1jY1aPTKvg04+KzFvYHXnTqIzfnT24utEDfxLI+y/6Krus8sv7c06GHNBtX440oZ48XYl0cR+olVST+K8ThMtC47rogsOkY0sTg64ngWbfD9R2E86SW146hg5Jm2H0z2yhBrZyF2T0WExVMhCIHr9fYTLcS5vYZnL+Ax9FgonrIGNiExMIkIpLfiG1OrXI9Y+/xVKHr45EkyJarBJy4TnaZUMAUnquTOv
tp=PSH4x9tBWm7pxmfyxn4MO2bgQ38KnNVzAhb/QSaLlHMGZ5r6CynE2AHPCgw+QLFCWFYJUUy7CsWiZw95+ajCP+io4VSly1Mufs08pWtrfIvVU+0XAhlJORZnW0Pr9OFJ4gfsFbEWB8Z4UZDMHj+tLqBvxNJ9PdCL7C5PYGsvyRdOOb59OHvDFFRpUSGf0PPB0vAJlm4eAsOY/4wrJdNRqp95DapUA0lHVRwgLjSJibQLKgWlkD7DsPdKZ60Q=
tp=P4rjK8Eh+MfbQVpu6cZn8sZ+DDtm4EN/CpzVcwIW/0Emi5RzBmea+gspxNgBzwoMPkCxQlhWCVFMuwrFomcPefmowj/oqOFUpctTLn7NPKVra3yL1VPtFwIZSTkWZ1tD6/ThSeIH7BWxFgfGeFGQzB4/rS6gb8TSfT3Qi+wuT2BrL8kXTjm+fTh7wxRUaVEhn9DzwdLwCZZuHgLDmP+MKyXTUaqfeQ2qVANJR1UcIC40iYm0CyoFpZA+w7D3SmetE
tp=PG/xdbwr8t20OOdfLsEAsixm6S7KKsRfmoesk+bpKoHR6dMUNmvAZodasXK7YGmNWUkWtHz8V7CIjjkJDNxOFOp4qo2oPG1SPvh9y4YbbIpIGvNTmA0+BX/0FumXgPwrfNCwK75zkxRzNQ0XuW76X/SOpfUcqmhMyOsrmCSQ5yTpev1HTLO8MhHMt7dZtEtgDZAxgS5v4m2UsHFJ1jPTe46OjoAHCs54GPl5j1ELLikUlJa3mR7JSaxFFl0M=
tp=PjY9Stxv8XW8K/LdtDjnXy7BALIsZukuyirEX5qHrJPm6SqB0enTFDZrwGaHWrFyu2BpjVlJFrR8/FewiI45CQzcThTqeKqNqDxtUj74fcuGG2yKSBrzU5gNPgV/9Bbpl4D8K3zQsCu+c5MUczUNF7lu+l/0jqX1HKpoTMjrK5gkkOck6Xr9R0yzvDIRzLe3WbRLYA2QMYEub+JtlLBxSdYz03uOjo6ABwrOeBj5eY9RCy4pFJSWt5keyUmsRRZdD
tp=PO3KDxc5tmAammdt2sMxM/PJ7iTDkCm4nSBvH6BBp05mu6/c0MkSU0UaozqRdF6xwh1gd3vLgV0GWCfUamBUB6Bdo1CglnTQCeheRmUmdqBCJuXnAZELSI4WNvfwkzJqyQ0nOZAElHU3hoYc3ZnXQo9nIOLvKislPzkH2ZeZR4Ur7XDkJwb8+QCr8sRQd0FB8vEoUoNfGIerX0w9wVhZ6pAmFgZTeZFQgieSdCohVKQ1h31VncAEAux1YvyY=
tp=PoHfIpDtyg8XObZgGppnbdrDMTPzye4kw5ApuJ0gbx+gQadOZruv3NDJElNFGqM6kXRescIdYHd7y4FdBlgn1GpgVAegXaNQoJZ00AnoXkZlJnagQibl5wGRC0iOFjb38JMyaskNJzmQBJR1N4aGHN2Z10KPZyDi7yorJT85B9mXmUeFK+1w5CcG/PkAq/LEUHdBQfLxKFKDXxiHq19MPcFYWeqQJhYGU3mRUIInknQqIVSkNYd9VZ3ABALsdWL8m
tp=P5YQezOXj3D4QJtsTzS1fQiKaloz2y5vr+gt4RXsMuV1uz8JiCmHrarix0+OSspZOmn5+N42MIVLF5prvMugLQhdIGLiYNkjqFhEFJBbzueCAsDi1wmq2v9X8Un0ny/wAe2l/N07tXyNYZrnTXLJhweUZjTJlIXgwQL4Uu5OWKoKXODQ7PwQEoeQIfiyvcFV01R2BSSdFMDMvaNA9elRUXI5BS6dgS44eRd9y4/h6Me7GzQ18/oGBHRrCsws=
tp=PDVtLg+WEHszl49w+ECbbE80tX0IimpaM9sub6/oLeEV7DLldbs/CYgph62q4sdPjkrKWTpp+fjeNjCFSxeaa7zLoC0IXSBi4mDZI6hYRBSQW87nggLA4tcJqtr/V/FJ9J8v8AHtpfzdO7V8jWGa501yyYcHlGY0yZSF4MEC+FLuTliqClzg0Oz8EBKHkCH4sr3BVdNUdgUknRTAzL2jQPXpUVFyOQUunYEuOHkXfcuP4ejHuxs0NfP6BgR0awrML
tp=PdoW6PIQQgUZ+mShqrTz9IUfpbFGRGLApXXsYYGc5zDXbfKhQZKlnW18coXaCAX1KJIAIask89HXzrPMD6nBTH0cWP0fFWTt6Yy2HObUel5cmPi4CzncauYPBxKQ4T6ASIuprfO5OZtAJSPwfOpl9qy7IHjMz+qvwSnynBlh3i4WT8juBHGHYUN0wLMAtsPAgCQj+CoKASUzSMRu+ifc5oZpghgy2yIH3sWtsv1pn95FE3pdxLJYO3hy4M/Y=
tp=PQ4TFRnaFujyEEIFGfpkoaq08/SFH6WxRkRiwKV17GGBnOcw123yoUGSpZ1tfHKF2ggF9SiSACGrJPPR186zzA+pwUx9HFj9HxVk7emMthzm1HpeXJj4uAs53GrmDwcSkOE+gEiLqa3zuTmbQCUj8HzqZfasuyB4zM/qr8Ep8pwZYd4uFk/I7gRxh2FDdMCzALbDwIAkI/gqCgElM0jEbvon3OaGaYIYMtsiB97FrbL9aZ/eRRN6XcSyWDt4cuDP2
tp=P+xS5iZgkWQdMtTy3TPmD6Jzv/pboFx0ADZVml3jE1IU55M/vaX05mT7+TBmUC3GNhwvk9kHcQTTt5w69jwwrKq8Zz152tYYqo7/IhXR8Y0ZxZCbuDeFvSYPjf3eKdGa7U9pK9WXf7SbyfLvm68/n1DvyIw/zxTCUNQpYjSdP/euH2dOvZNQbR8smHC24jhd2+jx/ck+1PL4uNAPtMzhOb6cTm8rysSNqgnNVlU7mYoaFFDRcXLt+hM5uQgY=
tp=Pl4tv8/sUuYmYJFkHTLU8t0z5g+ic7/6W6BcdAA2VZpd4xNSFOeTP72l9OZk+/kwZlAtxjYcL5PZB3EE07ecOvY8MKyqvGc9edrWGKqO/yIV0fGNGcWQm7g3hb0mD4393inRmu1PaSvVl3+0m8ny75uvP59Q78iMP88UwlDUKWI0nT/3rh9nTr2TUG0fLJhwtuI4Xdvo8f3JPtTy+LjQD7TM4Tm+nE5vK8rEjaoJzVZVO5mKGhRQ0XFy7foTObkIG
tp=Piy92pR1SdFGWDi0NQ+is5RqMVE/JYvDpibeQYc5mTuy5tt6C3BABXPL9/uGGV9gEaWUxOz/7LHIDTJ5BLABhQw90Ah7sr1ODSq/jZc1x3REOausBD1ZYhg3rpboqBVdag7/AJabZof4d3MwqwBAc/o0cg0HjlgqCT8/D8s0i69QzcQDicsR7b++ubAtQ2G3EmNIjL+D7vMgRJF5jBBA15QOlhS3B0RhzrzWFEdC+sW+rkR4UdcMSy9mfSw3Tb+LT
004004:0000 The source file '/BDMV/STREAM/00031.m2ts' is corrupt or invalid at offset 12886548480, attempting to work around
tp=PQYY4Drtr7R4rioWAC1GZne9HiQAYJhSt+xNj5Y23mCsvivdbdunhOfmhwoczXBNBzrpm+rXGCrE0pt4Ue8zGW05329jO1Qt0jwjpKS2aGY5CBb4u8pntbkPXc5J8KOWXAqQ5i2Y4P4n922UMIONBQTBRvvnFPCPfR8LzHYsy/zMVbpDmIkPgfTB048P98VZp9aVeZVY+Q4pztMapV6p03+XP7Tq2CLsWOYKCR0/k598cb5ts+0gg87DzZt8=
tp=PQsr8UEGGOA67a+0eK4qFgAtRmZ3vR4kAGCYUrfsTY+WNt5grL4r3W3bp4Tn5ocKHM1wTQc66Zvq1xgqxNKbeFHvMxltOd9vYztULdI8I6SktmhmOQgW+LvKZ7W5D13OSfCjllwKkOYtmOD+J/dtlDCDjQUEwUb75xTwj30fC8x2LMv8zFW6Q5iJD4H0wdOPD/fFWafWlXmVWPkOKc7TGqVeqdN/lz+06tgi7FjmCgkdP5OffHG+bbPtIIPOw82bf
tp=P0QcKQvIOuwhTs/raCTlWkOOj22S62i8mZ1QZAGUNItlxIU611oiZ4wD4bfKQAiS0Shq0MABS/8C8V15VHkB6qma09KFdiUpXaacg42ssE2KTbOhqVbm1q+CXkNEyqRYlzF0zdSte1E9pi+MaWzIVD7Xx4RcpfTWc3C9ZrHFfoshZS3fv7IbTqC+Wtjd3iozT2NqrF29pagKsp1DO5iIGmTbMFen1f1OVfCdZylywpx0R1e/XdKqVmykuA+k=
tp=PSLiK6tEHCkLyDrsIU7P62gk5VpDjo9tkutovJmdUGQBlDSLZcSFOtdaImeMA+G3ykAIktEoatDAAUv/AvFdeVR5AeqpmtPShXYlKV2mnIONrLBNik2zoalW5tavgl5DRMqkWJcxdM3UrXtRPaYvjGlsyFQ+18eEXKX01nNwvWaxxX6LIWUt37+yG06gvlrY3d4qM09jaqxdvaWoCrKdQzuYiBpk2zBXp9X9TlXwnWcpcsKcdEdXv13SqlZspLgPp
tp=Pt2aNiXFGpAzmKXKhAGFffRpauR4xCTRkJPV+/EGLYylJq3ijaSfMR3kD8qUegb0FlCteIhLWmd5hlDT/a2NHWajXbMENn7IN1ryzHOom0J804V1ZmycSJTMbAnPU91BOjlBhMGhC0b88X0v2fDFSQMPLvSdwleWMXJZX0ye6SEV657F0gGuQCWxuuAcf6Yf6YnQzsnmduHqMrDucfaTVbxVXGrgEIl1fLqy/yqSRWoIv2pku5mdYoE5YnNs=
tp=PMPwwNrdmjYlxRqQM5ilyoQBhX30aWrkeMQk0ZCT1fvxBi2MpSat4o2knzEd5A/KlHoG9BZQrXiIS1pneYZQ0/2tjR1mo12zBDZ+yDda8sxzqJtCfNOFdWZsnEiUzGwJz1PdQTo5QYTBoQtG/PF9L9nwxUkDDy70ncJXljFyWV9MnukhFeuexdIBrkAlsbrgHH+mH+mJ0M7J5nbh6jKw7nH2k1W8VVxq4BCJdXy6sv8qkkVqCL9qZLuZnWKBOWJzb
tp=Pn1IiyVdRiatW+pbSS4RJ04ceLoVVV+baDd7SUJo6DNOmt0+TKVzAd5tsgFqBaS5YEouv5HfIuBwjpuC/cWmmLdlX29pBXjWN5zdFiBC8EyPiNAY2+m4h7LjuZKONRb+aJqygOLKjbT91cjQffzvn7vdT7+8El5s3+3zylFqBFkKvYV++g5yy/MemS9E4UcUflvu4Dx6Vj9QS86iA+q/Q8NGzKuLqSnx2iM/6VDU4AmqJ7cPwnd5Cf2kEpz8=
tp=PxTtOQ59SIslXUYmrVvqW0kuESdOHHi6FVVfm2g3e0lCaOgzTprdPkylcwHebbIBagWkuWBKLr+R3yLgcI6bgv3Fppi3ZV9vaQV41jec3RYgQvBMj4jQGNvpuIey47mSjjUW/miasoDiyo20/dXI0H3875+73U+/vBJebN/t88pRagRZCr2FfvoOcsvzHpkvROFHFH5b7uA8elY/UEvOogPqv0PDRsyri6kp8dojP+lQ1OAJqie3D8J3eQn9pBKc/
tp=P1REMR2HOnjH+iE9G8dsCOYGfsFLTmg3bc20f4h05v2PGYGmBnv1ZsQ2WKNDJDOyt2pSeCi/2N/4tEnvL06Y1U8eXfrmyxNzt99hOhfGILXzcAxcjpKVGbgyng9Yd/VAB3wbuIVo4i30gfhm7xYe5xBRrq5M0HaCV8+yQGuiCuYZqqf9bZH7sZ3zApHZo3psCD5XkAgp1L9X4HdxANf1aGfbgZxVpvC3fvYUBC+AiBEvQ8q1aCSx5aShdK24=
tp=PEnepOdURDEdhzp4x/ohPRvHbAjmBn7BS05oN23NtH+IdOb9jxmBpgZ79WbENlijQyQzsrdqUngov9jf+LRJ7y9OmNVPHl365ssTc7ffYToXxiC183AMXI6SlRm4Mp4PWHf1QAd8G7iFaOIt9IH4Zu8WHucQUa6uTNB2glfPskBrogrmGaqn/W2R+7Gd8wKR2aN6bAg+V5AIKdS/V+B3cQDX9Whn24GcVabwt372FAQvgIgRL0PKtWgkseWkoXStu
tp=PGMl8Niq+/Cwo6lktpnH3IzP2Fx1nu7uuBle24LFtVy9cfAD5vKv+B6NOkjmqcWJdaK9HAZU6tPT2CC2a3qjstfc626W5dxF/ZpYgAhvwGnwvl6YnSRbQJhfsWIwcuxKabsY07/R9xnHijvwAIsoy2vQCszc9u4058f0uBH1KyisMWBfaDjRZpLLOuEsiUixSBpb/gDjx1nZB0rGBxN2tIudObdx++ZoVqrpRTTgNlEEUfIVGgA/LtzfbGOI=
tp=PrtrEyxjJfDYqvvwsKOpZLaZx9yMz9hcdZ7u7rgZXtuCxbVcvXHwA+byr/gejTpI5qnFiXWivRwGVOrT09ggtmt6o7LX3OtuluXcRf2aWIAIb8Bp8L5emJ0kW0CYX7FiMHLsSmm7GNO/0fcZx4o78ACLKMtr0ArM3PbuNOfH9LgR9SsorDFgX2g40WaSyzrhLIlIsUgaW/4A48dZ2QdKxgcTdrSLnTm3cfvmaFaq6UU04DZRBFHyFRoAPy7c32xji
tp=Pwd9/z1idI5nkSIJ+IICkoCdcSRFdpvcdLdALTffdWbKMgIxf5oNUpOx1PYxi2d0RrV/Pe7NNeHbhSl7jTT1WyVP21RDau/aeMLqgCh9cWshwvTOy18EY+SNPyBgOnclsH5SNZXk+7PkEqFedhiz2RDS1bbANfwxnNVMDOxU/Qva6N1OFRnbJAPCZ8H7Ti+SQrzt9jcBztoWUIwZfLVqOLrGBASZErjRzPRtAsQuNcsYe1ULousFcEculj8A=
tp=PCdECK8Hff89YnSOZ5EiCfiCApKAnXEkRXab3HS3QC0333VmyjICMX+aDVKTsdT2MYtndEa1fz3uzTXh24Upe4009VslT9tUQ2rv2njC6oAofXFrIcL0zstfBGPkjT8gYDp3JbB+UjWV5Puz5BKhXnYYs9kQ0tW2wDX8MZzVTAzsVP0L2ujdThUZ2yQDwmfB+04vkkK87fY3Ac7aFlCMGXy1aji6xgQEmRK40cz0bQLELjXLGHtVC6LrBXBHLpY/A
tp=PjSvvcVO8nqDxk+zzZtXNIWGxVJjLZFlS4G/fEAfgmobgFryD3JfGfxhi1RB8Z1VJC4xb3a0QZXDUHjGW9wq+V2c2QP/+91C4jpCMs8J65sveTdk8lzgAldzayMntdBBBLKTt8CnkwzxZwDdV8JVS+97sefCTSYZwzYkZfJiSq4gPNyGplaB0NoWoyb7F0rwjCwITdTsPt/MuQNXoAdbnGebB6e2apoKXhtKtOq5/wCWtO7mVV1E9TeQmO84=
tp=PUOSpO40r73FTvJ6g8ZPs82bVzSFhsVSYy2RZUuBv3xAH4JqG4Ba8g9yXxn8YYtUQfGdVSQuMW92tEGVw1B4xlvcKvldnNkD//vdQuI6QjLPCeubL3k3ZPJc4AJXc2sjJ7XQQQSyk7fAp5MM8WcA3VfCVUvve7Hnwk0mGcM2JGXyYkquIDzchqZWgdDaFqMm+xdK8IwsCE3U7D7fzLkDV6AHW5xnmwentmqaCl4bSrTquf8AlrTu5lVdRPU3kJjvO
tp=PceMrWrCMyQdu3q5SpvnjUBYBwPlz6Msq01e7IhwoC/Vs8BAVB7fay79urJJ6YqIaVPJS6qpXaUFyTXFHbopDwaPd/Vil4mUz+yR83HMtbQPB7notfAZM67oASigF2MNl3rpcfa+CtyLAbbGxCFt31yINfLnYgVuhx1sHuP9j68JHEBEQy4ZN0HltjTAiqmqr8JXOdn+xA4krpjNAxznAClYRNk+8LdBPNu+CQAZ57QFW52XXDGgGLkrS64o=
tp=PG+hWBXHjK1qwjMkHbt6uUqb541AWAcD5c+jLKtNXuyIcKAv1bPAQFQe32su/bqySemKiGlTyUuqqV2lBck1xR26KQ8Gj3f1YpeJlM/skfNxzLW0Dwe56LXwGTOu6AEooBdjDZd66XH2vgrciwG2xsQhbd9ciDXy52IFbocdbB7j/Y+vCRxAREMuGTdB5bY0wIqpqq/CVznZ/sQOJK6YzQMc5wApWETZPvC3QTzbvgkAGee0BVudl1wxoBi5K0uuK
tp=PXcQJZK3tBvv5K5kNsUMVGZd1a1lDX6gdQj5QTBAb3vbxtXjQvLhukUra4WsrMr8KUaou9DqoA0NPPJv3+nBsLNHXLfr81KrdnWSeG3nOIbDYOEQrpkwgP3t2X1+GuMCgdTc70sADT6Adu0a2cuqDe085ZmTUxF95nTCPDSVoUfKRPrhvq7k0sNRBfu3hRFnn6JPDN0/NwDgPt66GnrGX2HGB+9UOeWDQd5qmxLn2mV2f+FWeosrhiaT2Sng=
tp=P6Va+FV3ECWSt7Qb7+SuZDbFDFRmXdWtZQ1+oHUI+UEwQG9728bV40Ly4bpFK2uFrKzK/ClGqLvQ6qANDTzyb9/pwbCzR1y36/NSq3Z1knht5ziGw2DhEK6ZMID97dl9fhrjAoHU3O9LAA0+gHbtGtnLqg3tPOWZk1MRfeZ0wjw0laFHykT64b6u5NLDUQX7t4URZ5+iTwzdPzcA4D7euhp6xl9hxgfvVDnlg0HeapsS59pldn/hVnqLK4Ymk9kp4
tp=PAM2f3zKpZhHr/wC1jbYCjKkHT7GfE7KCl3/8907H/2L2urUcteS1lJpTfTFVwVJzoNf53DLQTbstT6aSWHio5xFkL7QNLy0c/9fsmPSvzyIXCON+Vr04Z9uBjAs6rDOuzfbYgKMAmH+UF5VlXIlXEi33jBJvTXwU0iyf/wwrq59Mrm5alsTB6ETX/SWRj7cKXXWTCKMBT0/E9FoyD4TZw/UHz+/W49RfDnBZYxp8cO0TGQ2D+vgXjIWYXIs=
tp=Pnnj5EwDNn98yqWYR6/8AtY22AoypB0+xnxOygpd//PdOx/9i9rq1HLXktZSaU30xVcFSc6DX+dwy0E27LU+mklh4qOcRZC+0DS8tHP/X7Jj0r88iFwjjfla9OGfbgYwLOqwzrs322ICjAJh/lBeVZVyJVxIt94wSb018FNIsn/8MK6ufTK5uWpbEwehE1/0lkY+3Cl11kwijAU9PxPRaMg+E2cP1B8/v1uPUXw5wWWMafHDtExkNg/r4F4yFmFyL
tp=PYcS6Ma7ujV7UfkTWN0SsqeDQTvQ6M1Lx/LsebIf8GOWrOmcVhpltwJCZBA5Bs27QK6AxMcU04MHjdorC6S4kesQdq6GoUzuze4PoG4MemF93jNnOcpqaPQT2UoU50JQ/NorSJcV0HdQupoc4ReRh5Nm0FZMoOcLpo2unP4Niwina+t7BbSvmYpcHD20uRHpZMGTcDq67HAXiaZKXC7or9tiayaiez1SIRH2v4cU0NbiRPg4fmkdSX8PtY6A=
tp=PN9bCLmHEujGu7o1e1H5E1jdErKng0E70OjNS8fy7HmyH/BjlqzpnFYaZbcCQmQQOQbNu0CugMTHFNODB43aKwukuJHrEHauhqFM7s3uD6BuDHphfd4zZznKamj0E9lKFOdCUPzaK0iXFdB3ULqaHOEXkYeTZtBWTKDnC6aNrpz+DYsIp2vrewW0r5mKXBw9tLkR6WTBk3A6uuxwF4mmSlwu6K/bYmsmons9UiER9r+HFNDW4kT4OH5pHUl/D7WOg
tp=PQHO5G2yFt74OS4RQS56NbaqYvAOVOAFSmw+yoSCCEjBJqkbS6chy9VlUZ02kZCgQVoouGgvGhIGfhFKT31qW/Yu3RR5WQNMrdOasVgs6Pr8boBxefv1ktQVCwOmXCr7dzJNOTxSz6e/0CStNX90cjTeb9l+pvtegAy6bWIHn8mF/JECYPakm6C/IUc4Ly2tJXLSYGHqRJqMKhO4+2kng4yIfBJbDtSi0XLBwRkCXkc77q0miZoqRwKe8XqQ=
tp=PqRRdlkBzuRtshbe+DkuEUEuejW2qmLwDlTgBUpsPsqEgghIwSapG0unIcvVZVGdNpGQoEFaKLhoLxoSBn4RSk99alv2Lt0UeVkDTK3TmrFYLOj6/G6AcXn79ZLUFQsDplwq+3cyTTk8Us+nv9AkrTV/dHI03m/Zfqb7XoAMum1iB5/JhfyRAmD2pJugvyFHOC8trSVy0mBh6kSajCoTuPtpJ4OMiHwSWw7UotFywcEZAl5HO+6tJomaKkcCnvF6k
tp=P+wVhcwm14/oLRGCH8yqLJKWFrzl6FUvGLayUoUhDvzTHrNu/gaciaD1ul6c8NABKa9/rwdHQolsQ3NpBvY6HACzAvqVAh5G0/wQcTXTT4y9IAMZm70iK7iV4FvPTiQDIwPzz9eu+cAo3r4waS5Wci4lBU/Gd7w3ONoDyxzf0sgK1F/ktktxwlggAJeLolMfV7jRjJJC/CTRPhtvYF0iEA+FKBsiy45FluMZok8S2wbO7+qZAj/SV5ESM3Kk=
tp=P/ID1P/sFYXMJteP6C0Rgh/MqiySlha85ehVLxi2slKFIQ780x6zbv4GnImg9bpenPDQASmvf68HR0KJbENzaQb2OhwAswL6lQIeRtP8EHE100+MvSADGZu9Iiu4leBbz04kAyMD88/XrvnAKN6+MGkuVnIuJQVPxne8NzjaA8sc39LICtRf5LZLccJYIACXi6JTH1e40YySQvwk0T4bb2BdIhAPhSgbIsuORZbjGaJPEtsGzu/qmQI/0leREjNyp
tp=Pw/fFqI+QuartI1iW0PFYdfaMl+GLaUfJgjF5jSzO4F+6B5Jv7vH4uiNbSQ3nCIS/tArcXQGS1zW+GGdErqS30BxlCI6eQqYIHwyBqp4O4DvBxcjZSMsxYZblLhlKsdjkEX4zrmFJb9UaRCJEz7dqxP9d9gIhnaTf0b4jhPmcMh+Yn0N3U2MQxD6fhn3VPCgog6lckhYqqsAJ6AawR+uRKbe+4Z5eRUAactc7zZzP7SuHlxyjkbxAbZ1qTVo=
tp=PImdiN/DWeDtldaa+Ui513F/hh7n7bvSxQJ2lQKT6SL+Mmzh0c+bo26gs27nmcGDfMYbYNbod8dKGeTGKqyd9wx8jBCT4iVqSkweKA0mw6u4fgwGFr0tawBNgHOtjej/AF1FCnPTg5tUFk4VOHSAMloEsfKbx/qJ/1OpOJUNod7pEjCpQiIP35qp75xICOwknN59wGdYowrQjMuVJQoe4aC+VV7K/qBWyTTK3qerwCC7nBqslqu59hMU6K84=
tp=PRzRBBiJnYjfw1ng7ZXWmvlIuddxf4Ye5+270sUCdpUCk+ki/jJs4dHPm6NuoLNu55nBg3zGG2DW6HfHShnkxiqsnfcMfIwQk+IlakpMHigNJsOruH4MBha9LWsATYBzrY3o/wBdRQpz04ObVBZOFTh0gDJaBLHym8f6if9TqTiVDaHe6RIwqUIiD9+aqe+cSAjsJJzefcBnWKMK0IzLlSUKHuGgvlVeyv6gVsk0yt6nq8Agu5warJarufYTFOivO
004004:0000 The source file '/BDMV/STREAM/00031.m2ts' is corrupt or invalid at offset 12886554624, attempting to work around
tp=PdL5BXEqHjRrI1JPcuRkUwtUEgDzDKKgOAgjikrBuDnLFXkw0l7dBhnbfIllNvV5ZllD+csNg729G4BtT4M4Jv6uOGBgR/RTLgMc4PSe/FfrcOeSTYvqZyK2nm+fWuHWek+enkT73e+zmJryBAUwPqA9ppp+PXEMZz47lsJmgS8rfiSnIc0BE1/XXaHVmc8Gdogoh8K/z+PdoBHavAprlGTpKQ4/cuWOpOtSnhOke5SRe5HxZYTAK2BRalak=
tp=PoWtr23S+QVxKh40ayNST3LkZFMLVBIA8wyioDgII4pKwbg5yxV5MNJe3QYZ23yJZTb1eWZZQ/nLDYO9vRuAbU+DOCb+rjhgYEf0Uy4DHOD0nvxX63Dnkk2L6mcitp5vn1rh1npPnp5E+93vs5ia8gQFMD6gPaaafj1xDGc+O5bCZoEvK34kpyHNARNf112h1ZnPBnaIKIfCv8/j3aAR2rwKa5Rk6SkOP3LljqTrUp4TpHuUkXuR8WWEwCtgUWpWp
tp=PzHTNkageYTZhuUKRKJHyMpETm0nXarBx1l2j6l2MlUgsmmeuE+dFwVTxZ5vZ4XxDmjAHLZkxpZ9j1ReUva1VXrhqgWVXjpqYa44AsEOAuTKqcoQxG/KXhv+zvmAEbBQzWU2KjT2NOBEo66P1a4donXZpebz05A7PWYlFxqF79H6ZGjw7ILyOvLlwg9/1Auq2dAJbeYBOyjIzAU4hHM67aKtRp5uOIXQHLONzKUCALTvZpqfIsDsoM0h7y9k=
tp=PxfXV4Mx0zZGoHmE2YblCkSiR8jKRE5tJ12qwcdZdo+pdjJVILJpnrhPnRcFU8Web2eF8Q5owBy2ZMaWfY9UXlL2tVV64aoFlV46amGuOALBDgLkyqnKEMRvyl4b/s75gBGwUM1lNio09jTgRKOuj9WuHaJ12aXm89OQOz1mJRcahe/R+mRo8OyC8jry5cIPf9QLqtnQCW3mATsoyMwFOIRzOu2irUaebjiF0ByzjcylAgC072aanyLA7KDNIe8vZ
tp=P9r+wBUgY0pcxI5AZWKF24fu9nfa/iUkGJ1VJZF/O/+PVtgWzO15ADiJXbDW8shPJTaLrJb64AeRWNBB01CSeUEjS6GYNvefFlRDuwC3+wz9BUNQWPA8OpXg+mgHHXFaNqL8rM/Fl0M+pZL1YzVhcljLs+Swm0KPGKTUV5IbCEJOA/SQeP57/qe26vr53k5zOA+2PfUqCnBkK38tOvhOkqI7/aema98CQjiaXVKBNveXkGvuOhOUirKyFfkY=
tp=PsX66/va/sAVIGNKXMSOQGVihduH7vZ32v4lJBidVSWRfzv/j1bYFszteQA4iV2w1vLITyU2i6yW+uAHkVjQQdNQknlBI0uhmDb3nxZUQ7sAt/sM/QVDUFjwPDqV4PpoBx1xWjai/KzPxZdDPqWS9WM1YXJYy7PksJtCjxik1FeSGwhCTgP0kHj+e/6ntur6+d5OczgPtj31KgpwZCt/LTr4TpKiO/2npmvfAkI4ml1SgTb3l5Br7joTlIqyshX5G
tp=PTdylKGIMb/PtXqvu3/Bju3Dc5wIWL33HhW0F15dojACPxOZePyyKL7bC1wqBu2E11vsUTAURYx+cM+exNmb5X0uT6BiAdlzcC8YgjbpI17oE/C0c6luPqR7uz9LgC+LIs2qj/+BuPj16V+RPAuFHKS1hbyS+qblzmp2d8oOHcPsntlxIzW9aSuEf4O/mKRHcKn/j0kgTm+DIBF6u6qrG+l0A0UoKp47UPLjY79CypyZm00mISNqGPRfLT8I=
tp=PAQ0/rU3cpShiDG/z7V6r7t/wY7tw3OcCFi99x4VtBdeXaIwAj8TmXj8sii+2wtcKgbthNdb7FEwFEWMfnDPnsTZm+V9Lk+gYgHZc3AvGII26SNe6BPwtHOpbj6ke7s/S4AviyLNqo//gbj49elfkTwLhRyktYW8kvqm5c5qdnfKDh3D7J7ZcSM1vWkrhH+Dv5ikR3Cp/49JIE5vgyAReruqqxvpdANFKCqeO1Dy42O/QsqcmZtNJiEjahj0Xy0/C
tp=PCbivkq96h3jjdFaCZli7fJEgJSOxy8rXTDcYKnLo1ji/n7mdxM56NcVL96dofiTWaJSRBSSKB1QV6BnO/xjMmSfsKH6xkQQ/zFQyMMBAekuZljUku5Oz0hwhuDIEKKDupQIyOrKs9RsDF/28h2u6N8d5UHExuRJXQlyDcIo8T3TsstCBzOvxfDRfEjiVEFzG7aWcEfrIR3XZeHnxyiXY30shY/pxtI8k1EEcX1aQ36mYurEjSmLMtP4VPu4=
tp=P+F79+wm4r5Kveod443RWgmZYu3yRICUjscvK10w3GCpy6NY4v5+5ncTOejXFS/enaH4k1miUkQUkigdUFegZzv8YzJkn7Ch+sZEEP8xUMjDAQHpLmZY1JLuTs9IcIbgyBCig7qUCMjqyrPUbAxf9vIdrujfHeVBxMbkSV0Jcg3CKPE907LLQgczr8Xw0XxI4lRBcxu2lnBH6yEd12Xh58col2N9LIWP6cbSPJNRBHF9WkN+pmLqxI0pizLT+FT7u
tp=P/+Ve1r8WrtIpBVAVSW+5NLgNhVTN/QG7dI+B3UpOpBSVl4DziUBnWXm8cYiLauqadvOUL3baiYO1AZKQKksUq61lSKC9MTNhIxpAP4TgmnPHXsDkTDXgEPMTHyibg+RJY27l3oOmMnHx8fBlmseum63se4SgnL/Ldb1Z/Z37S+b3pbFjV12/3jYBG37uPcHPEZBEV5840tMTiFktx93F+xrcL1akRUsbZlXK2mLnttbr/2K6JhqA/hWk8p8=
tp=PSSHdVf/lXta/Fq7SKQVQFUlvuTS4DYVUzf0Bu3SPgd1KTqQUlZeA84lAZ1l5vHGIi2rqmnbzlC922omDtQGSkCpLFKutZUigvTEzYSMaQD+E4Jpzx17A5Ew14BDzEx8om4PkSWNu5d6DpjJx8fHwZZrHrput7HuEoJy/y3W9Wf2d+0vm96WxY1ddv942ARt+7j3BzxGQRFefONLTE4hZLcfdxfsa3C9WpEVLG2ZVytpi57bW6/9iuiYagP4VpPKf
tp=PiuaI1y+riqAnYCrdk8AbaAVSn5dj/cnMpV4pxWZdsowL3pqyfFzmEUgElyCuoB5lQpPkY1uXfpJFFLooFIjG6pvgCUG3NQ5H0dbdz6Fs4ub1jUUCRvMjnH5RV3f+JhL9Ch5GVfWiYBaMvg4AaNbIO0qSbnm9ggSHNqwfS71//OkwovbUkroQzljY6RfeFp0084w4fw6z21kMK+uuXViPfP1QKXMjMDHGBrbPY0W1AGnm2KD50oT5XePAH2Q=
tp=PJS0mmYrmiNcvq4qgJ2Aq3ZPAG2gFUp+XY/3JzKVeKcVmXbKMC96asnxc5hFIBJcgrqAeZUKT5GNbl36SRRS6KBSIxuqb4AlBtzUOR9HW3c+hbOLm9Y1FAkbzI5x+UVd3/iYS/QoeRlX1omAWjL4OAGjWyDtKkm55vYIEhzasH0u9f/zpMKL21JK6EM5Y2OkX3hadNPOMOH8Os9tZDCvrrl1Yj3z9UClzIzAxxga2z2NFtQBp5tig+dKE+V3jwB9k
tp=Pt3lsItxtRRmrRqw8zjCU+zfdx6K9dU5GqAGUgY/yXH9t3Kja2TRyJbRbE/Mkb0KbOe6YD87WCudIuDLQV9666K6gQHRXuMzczfiOTlEwQulByzURby5FxMIBm8z2fWyR2Ceb+fHnzZZNwLZ+985t4RBBqIdqT1CgAs34wOYpwK2iSspXNPp8TCohQQiv9g/Dv35K+OjnacNjvdz3Ml/cutxjZOBNuX+ZdEN3HrlrPcc5Sjb4OYrQhoK7YU4=
tp=PWHMEYrd5bCLcbUUZq0asPM4wlPs33ceivXVORqgBlIGP8lx/bdyo2tk0ciW0WxPzJG9CmznumA/O1grnSLgy0FfeuuiuoEB0V7jM3M34jk5RMELpQcs1EW8uRcTCAZvM9n1skdgnm/nx582WTcC2fvfObeEQQaiHak9QoALN+MDmKcCtokrKVzT6fEwqIUEIr/YPw79+Svjo52nDY73c9zJf3LrcY2TgTbl/mXRDdx65az3HOUo2+DmK0IaCu2FO
tp=Pqe30+us5IGLIPZJ1BCk/CwI6LZyXxL7QToFbm4oC5rlQKClf3Khxj7R62OcKhXo/FQz4M1EhGXM5q5Oyuz0fnbv5KQIYJq6HpjO6+MLuJIMz9lbJ4/ZS2rfFtFz+dgU4lBoN5yxi57cU4or+t+P5VbuOobtQ2eDBiZHUnnmEZfM+fsGQjPk5Tnkp0/EG66Mi95YPDkmBEk5N1PPXyY/I1LitnvTGKkvQ4g6pyIzNwMiRAq4oGDFs7c5Rzvs=
tp=P+1Iosqnt9PrrOSBiyD2SdQQpPwsCOi2cl8S+0E6BW5uKAua5UCgpX9yocY+0etjnCoV6PxUM+DNRIRlzOauTsrs9H527+SkCGCauh6YzuvjC7iSDM/ZWyeP2Utq3xbRc/nYFOJQaDecsYue3FOKK/rfj+VW7jqG7UNngwYmR1J55hGXzPn7BkIz5OU55KdPxBuujIveWDw5JgRJOTdTz18mPyNS4rZ70xipL0OIOqciMzcDIkQKuKBgxbO3OUc77
tp=PvkS1HoBxmVoWBp1bVSQzj/ttLaq29Hc7SG0j20BwWKnD+NwEc4r8mgnnFCty6HA/MI7FHNpqGgW7VLSRa7+q970UWzb0PtqAsRCgDFXpnyjlgO7e60TT2AkfbIOtrwzLQ6AFULRNLcM8PY6GmYOcVIUScg62gY/xVP41bE0ktwClVYndqRy6NkDRWsihIV4PJdYQE4aQID6Txa3yhgUAKsja/DMfW0xoK5xWrs//MZHzj9WLu10MyVhr4qs=
tp=PqKMGxb5EtR6AcZlaFgadW1UkM4/7bS2qtvR3O0htI9tAcFipw/jcBHOK/JoJ5xQrcuhwPzCOxRzaahoFu1S0kWu/qve9FFs29D7agLEQoAxV6Z8o5YDu3utE09gJH2yDra8My0OgBVC0TS3DPD2OhpmDnFSFEnIOtoGP8VT+NWxNJLcApVWJ3akcujZA0VrIoSFeDyXWEBOGkCA+k8Wt8oYFACrI2vwzH1tMaCucVq7P/zGR84/Vi7tdDMlYa+Kr
tp=PG89ffGWk16cwQaNFcu7tw8iyIpiaUBfdZHwmzzd8xrH6ScyBWgtYl6hGGA+v+ns0QhVVAlWtnIekQJ5wKeUvOH+f1p4RGViZe9/IPMNou1mz1CkgLLS15TZHSIDGabWL3ef8AUAfSeNdXs37xenFfmqltXo6XV3vtLfN5z6tyloIbxAc6P9skNfAbP42fKKM/KbUsT2L3lLccCbg0DSvUL2wEXQgEQg7b0Vbyu3/1v/GGEaFqPokR2lOXtk=
tp=PC/+THxvPX3xlpNenMEGjRXLu7cPIsiKYmlAX3WR8Js83fMax+knMgVoLWJeoRhgPr/p7NEIVVQJVrZyHpECecCnlLzh/n9aeERlYmXvfyDzDaLtZs9QpICy0teU2R0iAxmm1i93n/AFAH0njXV7N+8XpxX5qpbV6Ol1d77S3zec+rcpaCG8QHOj/bJDXwGz+NnyijPym1LE9i95S3HAm4NA0r1C9sBF0IBEIO29FW8rt/9b/xhhGhaj6JEdpTl7Z
tp=P8TiCiDSt2MzI45DsIvqudXL2bSXubw2xFlA7AVpEHAhdGQQkOheMU69HM6Wk25nF+wOGkvQHHTOtooLsAyNH6T7AxDTYI+pyPGMIDC4QwIp8xQAudpw6/E6CQToIw3tVY9GfM+1vDsmtrhXTB4tFbFzv59RNxIMze+rF9GxWIKDcW0lq6r4fN5pKDCI8Wzgi5+L/BYGYi1jwd3xkktEzB/kcpjLPZ1qysZEzlkivRBXSR5c62dnk0zRFGTE=
tp=PNUoqQPE4gog0rdjMyOOQ7CL6rnVy9m0l7m8NsRZQOwFaRBwIXRkEJDoXjFOvRzOlpNuZxfsDhpL0Bx0zraKC7AMjR+k+wMQ02CPqcjxjCAwuEMCKfMUALnacOvxOgkE6CMN7VWPRnzPtbw7Jra4V0weLRWxc7+fUTcSDM3vqxfRsViCg3FtJauq+HzeaSgwiPFs4Iufi/wWBmItY8Hd8ZJLRMwf5HKYyz2dasrGRM5ZIr0QV0keXOtnZ5NM0RRkx
tp=PzHc+6QxlZCTTn3WtvKeppkqOCeUOKnG0VBffKIh4syJBvylLa7AKY+mdipuUJPm93N/LFHMiDoj9Y97YUj2GwUY9hqzXavk7CzU9u0Xxx/kqBMaqzi6LtPOyaetT3ubhp1xWCaOHtAxb5U4ZTwIDI7yoTqxspVZqVthZZvmCzKdVfxiQZfbqBn3U3OFXgafmS0e2GNyyyaWHTHciET2MKD17PzFebR8I/E0I54F9kE12p/CmmUKZF8b+JKY=
tp=Pf9h5H8x3PukMZWQk0591rbynqaZKjgnlDipxtFQX3yiIeLMiQb8pS2uwCmPpnYqblCT5vdzfyxRzIg6I/WPe2FI9hsFGPYas12r5Ows1PbtF8cf5KgTGqs4ui7TzsmnrU97m4adcVgmjh7QMW+VOGU8CAyO8qE6sbKVWalbYWWb5gsynVX8YkGX26gZ91NzhV4Gn5ktHthjcssmlh0x3IhE9jCg9ez8xXm0fCPxNCOeBfZBNdqfwpplCmRfG/iSm
tp=P/1n4AZ67lrAQaUKs7vL2sY1bhRepHdqSCiUDJuTFJm+7bgix4xpdIHtNQ5eYwKBYaQXs5ofccgqli0IvcFdfxft1/+PMqfKcV60v+6vlDnLiA+9sfT3v++ChRcHxqPrBaUIHQ4Z7jEL9f0D3AyLYQWWWG6ETQQ6Ta5MOCGV4tsYaRsrBJEO8AnagqOcCeH7UU/E/8ybeDTguDpfX1ukc3ZZAgB2l6Y1/8F68BVm15CAkpiQ6K7/AHZ2RTQk=
tp=PGIGU8v9Z+AGeu5awEGlCrO7y9rGNW4UXqR3akgolAybkxSZvu24IseMaXSB7TUOXmMCgWGkF7OaH3HIKpYtCL3BXX8X7df/jzKnynFetL/ur5Q5y4gPvbH097/vgoUXB8aj6wWlCB0OGe4xC/X9A9wMi2EFllhuhE0EOk2uTDghleLbGGkbKwSRDvAJ2oKjnAnh+1FPxP/Mm3g04Lg6X19bpHN2WQIAdpemNf/BevAVZteQgJKYkOiu/wB2dkU0J
tp=PLDO1uhi9/cjUF141wbGGEyoRm2akQ+rVlEhwHSou6p6pwz9tT36+pvNfOObjSuMkoDYIY+4My0NHper2UFMqlpXOH4Ju3acjoxnwiA+K645p2XEZq/mXZaGmnoqb2WeMRx2SKZ2Xy03yr664s6Mk9og+BLqAhxx/G9s/HPWK8K5RHbOs4vS5jUbxHCdi+PIUMTDA8Vajz7e3rDYXPHHXYfkX4GV925yphKmvWilkYQkgiyNpq+24alh/Op0=
tp=PodQ/iywztboYvf3I1BdeNcGxhhMqEZtmpEPq1ZRIcB0qLuqeqcM/bU9+vqbzXzjm40rjJKA2CGPuDMtDR6Xq9lBTKpaVzh+Cbt2nI6MZ8IgPiuuOadlxGav5l2Whpp6Km9lnjEcdkimdl8tN8q+uuLOjJPaIPgS6gIccfxvbPxz1ivCuUR2zrOL0uY1G8RwnYvjyFDEwwPFWo8+3t6w2Fzxx12H5F+BlfducqYSpr1opZGEJIIsjaavtuGpYfzqd
tp=PZBs666BeCRcyD8PNcsbiOzJckD31/vD6YjrIxKnanRA0ViWc5bBv69RKf3MUyjssvcC7PK1iNiWdjOhQxnHLgqAx4u2OXltz/NSkYDxiqp3nz2uPO/cGGmFBpC01HjPEe0t/e/kuJXPiO0JkkMfJHmBiiUuxGeqK4S+9GsdEH2jZXxReU4RJEuQWnORmnHGHMeGQ8cYXsRCf/Zrhn6nMALgUIWJ3ymlTRriUEbZIkCbuDz48fsciz5w/tJQ=
tp=PWWoJp2QbOuugXgkXMg/DzXLG4jsyXJA99f7w+mI6yMSp2p0QNFYlnOWwb+vUSn9zFMo7LL3AuzytYjYlnYzoUMZxy4KgMeLtjl5bc/zUpGA8Yqqd589rjzv3BhphQaQtNR4zxHtLf3v5LiVz4jtCZJDHyR5gYolLsRnqiuEvvRrHRB9o2V8UXlOESRLkFpzkZpxxhzHhkPHGF7EQn/2a4Z+pzAC4FCFid8ppU0a4lBG2SJAm7g8+PH7HIs+cP7SU
tp=PBroYezaUY9fIS4rNJZwHfgYbTJilxSusSKdfzGx13dZS6L2TLLLnuau11b++k2V1RE7n4IdQUL7iK631WQ6183pRxWhJR34XRdQEriZiLWW93YO6zpizcpWw2NEs7G0ygvzHgCQPXy5nqFo1ShpUK2WUukH9ppttV7AxDkZkKE3ufxaqt70dB2RzNX4TmBiD0kyiMfACFKEwNwgDabItKzYiBxnQ7tiMnaNARjPHCy3XxKzf5EjKtBUiQBE=
tp=P7FQK7wa6GHs2lGPXyEuKzSWcB34GG0yYpcUrrEinX8xsdd3WUui9kyyy57mrtdW/vpNldURO5+CHUFC+4iut9VkOtfN6UcVoSUd+F0XUBK4mYi1lvd2Dus6Ys3KVsNjRLOxtMoL8x4AkD18uZ6haNUoaVCtllLpB/aabbVewMQ5GZChN7n8Wqre9HQdkczV+E5gYg9JMojHwAhShMDcIA2myLSs2IgcZ0O7YjJ2jQEYzxwst18Ss3+RIyrQVIkAR
tp=PrZPVq0TvSzucwZVaBRO76EFH99BfQ0BTcoF92bhY0gIMjJaJ9CtJTkoBHsPeV+pTTBoBcPnVpyw9jDLVGrtucplGHb8T0p50pvca5rBfpDPcZMOFQEfiebTxgUcoqt/ySXoSX89KRpEZhpbtFmsrc/5sA4ECCNXXQLkYJh0E+Xme2kZR0fHPWbw4v49c96CRsCKu7cHwTilRODmdjmS7QrXIBN/CTszlM9svLXFNvOcnjwELP2Xbtadcp3Q=
tp=PUExsTa2T1atE70s7nMGVWgUTu+hBR/fQX0NAU3KBfdm4WNICDIyWifQrSU5KAR7D3lfqU0waAXD51acsPYwy1Rq7bnKZRh2/E9KedKb3GuawX6Qz3GTDhUBH4nm08YFHKKrf8kl6El/PSkaRGYaW7RZrK3P+bAOBAgjV10C5GCYdBPl5ntpGUdHxz1m8OL+PXPegkbAiru3B8E4pUTg5nY5ku0K1yATfwk7M5TPbLy1xTbznJ48BCz9l27WnXKd0
tp=PDGGOSOdmt4TGTku7qCnxj+esYNDYgHQSg0LShft8O5Bac6pQXuit4Ut+EzebraMTJiF3qYLF5i23DkVItBBHp2SlAo4P3JPFJ/vj014xpQT+hDAndHJgfD8LD1jmmhNNdt+izngQ8Ve9Y+Z1GxTg9H1Ms6OxRidlqBouWtzHAi8U+nHodXx9oMfXfukhAkNvDG98U/zZIi50nf//KzvpNA66DsO438z1laqu277/PZvbSsw4/CMYlgkY3EI=
tp=Ps7wnpAxhjkjnZreExk5Lu6gp8Y/nrGDQ2IB0EoNC0oX7fDuQWnOqUF7oreFLfhM3m62jEyYhd6mCxeYttw5FSLQQR6dkpQKOD9yTxSf749NeMaUE/oQwJ3RyYHw/Cw9Y5poTTXbfos54EPFXvWPmdRsU4PR9TLOjsUYnZagaLlrcxwIvFPpx6HV8faDH137pIQJDbwxvfFP82SIudJ3//ys76TQOug7DuN/M9ZWqrtu+/z2b20rMOPwjGJYJGNxC
tp=PSxHSd0iQTXZdednqJe9QTJFAtxKmv6qf+REnryYDtTnBalNDU+DeolT9TIOB1FYgCQus3JtEKs/z+nNeklH7YW77bMGsleCuKJ1Ckp4PU5tu04VgF1l9jOtxG/8/BSCgq0hYt3248b5JrsSdaJLlLIS9TCXUToTLK2Nhd8M00a1FFOe3xVQriynTfppLMrmplSMADjWQ5lM7S4307Ww81vKIGt96G00n7Uw2uzXbrBj/ZtnO/sWVvgYSiYM=
tp=PGhOwPksR0ndIkE12XXnZ6iXvUEyRQLcSpr+qn/kRJ68mA7U5wWpTQ1Pg3qJU/UyDgdRWIAkLrNybRCrP8/pzXpJR+2Fu+2zBrJXgriidQpKeD1ObbtOFYBdZfYzrcRv/PwUgoKtIWLd9uPG+Sa7EnWiS5SyEvUwl1E6EyytjYXfDNNGtRRTnt8VUK4sp036aSzK5qZUjAA41kOZTO0uN9O1sPNbyiBrfehtNJ+1MNrs126wY/2bZzv7Flb4GEomD
001003:0020 DEBUG: Code 2 at <:[}Wfm2Jp0@X.X_ML"I:213131111
001003:0020 DEBUG: Code 167 at aQz@ofj}|gB~qlTc:c}Y3:213132997
001003:0020 DEBUG: Code 184 at aQz@ofj}|gB~qlTc:c}Y3:213132997
001003:0020 DEBUG: Code 5 at aQz@ofj}|gB~qlTc:c}Y3:213132997
004007:0010 AV synchronization issues were found in file 'D://The_Great_Gatsby_t00.mkv' (title #1)
004008:0010 AV sync issue in stream 1 at 1:05:54.346 with duration of 10.666ms : audio gap - 1 missing frame(s)
001003:0020 DEBUG: Code 258 at ^lI\~8&p6,_cdN'VR=$wA*mT^:121263521
001003:0020 DEBUG: Code 2147483906 at Ym%b"z6uUTBDDpud:29393953
Great Gatsby
thedigitalhobo
- Contact:
Great Gatsby
- MakeMKV_log-Gatsby.txt
- (136.42 KiB) Downloaded 496 times
