I got the following error:
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00912.m2ts' at offset '2359296'
Backup failed
Besides when MKV opens up it doesn't show me the titles in the disc so I can select them it will only give me the option to backup the entire disc. Why is that?
thanks
IRON MAN 3 errors out
Re: IRON MAN 3 errors out
Do you mean the big button with the disk on it is greyed out, so you can't click on it?
necrosis
I think this is the same problem I am having. Forgot to copy the error and trying to back it up again now.
Most annoying part is it errored on the very end of the backup.
