I am trying to convert Spooks-Season 5 Disk 2 to MKV file however the first episode on the disk fails at the end of the conversion. The title00.mkv gets to about 1/3 converted before it fails. I am able to play the vob on my pc. All other disk from Spooks convert correctly.
MakeMKV v1.4.11 beta win(x86-release) started
Opening files on harddrive at Z:/Spooks- Series 5 [Disc 2]/VIDEO_TS/
Calculated BUP offset does not match one in IFO header.
Titleset start sector mismatch for titleset 1 : 61 != 37
Titleset start sector mismatch for titleset 2 : 7575 != 7545
Titleset start sector mismatch for titleset 3 : 1639355 != 1639298
Title #0 has length of 25 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #1 has length of 0 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #2 has length of 0 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Cell 9 was discarded (structure protection?)
Title #3 was added (8 cell(s), 0:57:14)
Title #4 was added (8 cell(s), 0:57:39)
Title #5 has length of 6 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory Z:/Spooks- Series 5
Failed to save title 0 to file Z:/Spooks- Series 5/title00.mkv
0 titles saved, 1 failed
Spooks-Season 5 Disk 2 Error
- Contact:
Re: Spooks-Season 5 Disk 2 Error
Looks like you are opening broken DVD rip from a hard drive.
