Rip Failed - A Good Day to Die Hard
ab1245
Post by ab1245 »
Hi I am trying to rip A Good Day to Die Hard and failed.
MakeMKV v1.8.5 win(x64-release) started
Loaded 32 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using disc-specific SVQ from builtin/dsall.svq
BD+ code processed, got 1 FUT(s) for 53 clip(s)
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00341.mpls was added as title #0
Title #00012.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #1
Title #00300.mpls has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00301.mpls was added as title #2
Title #00302.mpls has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00303.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00304.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00305.mpls was added as title #3
File 00306.mpls was added as title #4
File 00307.mpls was added as title #5
File 00801.mpls was added as title #6
File 00326.mpls was added as title #7
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00802.mpls is equal to title 00800.mpls and was skipped
Title 00852.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00801.mpls and was skipped
Title #00270.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00349.mpls was added as title #8
File 00350.mpls was added as title #9
File 00351.mpls was added as title #10
Title #00358.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00359.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00360.mpls has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00361.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00362.mpls has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00363.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00364.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00365.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00366.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00367.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00368.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00369.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00370.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00371.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00372.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00373.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00382.mpls was added as title #11
File 00311.mpls was added as title #12
File 00312.mpls was added as title #13
File 00313.mpls was added as title #14
File 00314.mpls was added as title #15
File 00315.mpls was added as title #16
File 00316.mpls was added as title #17
File 00317.mpls was added as title #18
Title #00318.mpls has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00320.mpls was added as title #19
File 00319.mpls was added as title #20
File 00321.mpls was added as title #21
File 00322.mpls was added as title #22
File 00323.mpls was added as title #23
File 00324.mpls was added as title #24
File 00615.mpls was added as title #25
Title #00630.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00632.mpls has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00613.mpls was added as title #26
Title #00618.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00617.mpls has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00619.mpls has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00620.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00616.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00621.mpls has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00614.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00631.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00633.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00637.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00634.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00635.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00638.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00636.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00629.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00612.mpls was added as title #27
File 00622.mpls was added as title #28
Title #00623.mpls has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00625.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00626.mpls has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00627.mpls was added as title #29
Title #00628.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00624.mpls was added as title #30
Title #00640.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00641.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00642.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00643.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00644.mpls has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00645.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00639.mpls was added as title #31
File 00376.mpls was added as title #32
File 00353.mpls was added as title #33
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00280.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01288.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00281.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00282.m2ts has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00283.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00284.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00285.m2ts was added as title #34
File 00286.m2ts was added as title #35
File 00311.m2ts was added as title #36
File 00312.m2ts was added as title #37
File 00313.m2ts was added as title #38
File 00314.m2ts was added as title #39
File 00316.m2ts was added as title #40
File 00317.m2ts was added as title #41
Title #00318.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00319.m2ts was added as title #42
File 00320.m2ts was added as title #43
File 00321.m2ts was added as title #44
File 00322.m2ts was added as title #45
File 00324.m2ts was added as title #46
File 00325.m2ts was added as title #47
File 00342.m2ts was added as title #48
File 00343.m2ts was added as title #49
File 00344.m2ts was added as title #50
File 00350.m2ts was added as title #51
File 00351.m2ts was added as title #52
File 00352.m2ts was added as title #53
Title #00360.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00361.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00362.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00363.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00364.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00365.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00366.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00367.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00368.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00369.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00370.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00371.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00372.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00373.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00374.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00375.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00380.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00381.m2ts was added as title #54
File 00435.m2ts was added as title #55
Title #00490.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00315.m2ts was added as title #56
File 00323.m2ts was added as title #57
Title #01309.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01495.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01496.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01497.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01498.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01499.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01500.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01501.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01502.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01503.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01504.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01505.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01506.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01507.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01508.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01509.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01510.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01511.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01512.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01513.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01514.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01515.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01516.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01517.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01518.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01519.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01520.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01521.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01522.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01523.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01524.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01525.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01526.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01527.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01528.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01529.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01530.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01531.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01532.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01533.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01534.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01535.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01536.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01537.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01538.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01539.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01540.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01541.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01542.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01543.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01544.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01545.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01546.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01547.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01548.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01549.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01550.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01551.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01552.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01553.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01554.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01555.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01556.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01557.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01558.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01559.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01560.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01561.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01562.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01563.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01564.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01565.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01566.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01567.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01568.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01569.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01570.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01571.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01572.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01573.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01574.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01575.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01576.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01577.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01578.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01579.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01580.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01581.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01582.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01583.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01584.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01585.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01586.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01587.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01588.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01589.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01590.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01591.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01592.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01593.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01594.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01595.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01596.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01597.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01598.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01599.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01600.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01601.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01602.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01603.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01604.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01605.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01606.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01607.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01608.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01609.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01610.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01611.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01612.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01613.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01614.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01615.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01616.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01617.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01618.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01619.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01620.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01621.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01622.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01623.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01624.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01625.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01626.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01627.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01628.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01629.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01630.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01631.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01632.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01633.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01634.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01635.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01636.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01637.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01638.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01639.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01640.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01641.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01642.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01643.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01644.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01645.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01646.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01647.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01648.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01649.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01650.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01651.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01652.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01653.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01654.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01655.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01656.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01657.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01658.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01659.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01660.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01661.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01662.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01663.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01664.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01665.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01666.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01667.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01668.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01669.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01670.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01671.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01672.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01673.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01674.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01675.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01676.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01677.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01678.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01679.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01680.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01681.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01682.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01683.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01684.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01685.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01686.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01687.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01688.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01689.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01690.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01691.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01692.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01693.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01694.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01695.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01696.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01697.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01698.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01699.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01700.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01701.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01702.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01703.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01704.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01705.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01706.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00801.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00803.m2ts was added as title #58
Title #00805.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00807.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00909.m2ts was added as title #59
File 00911.m2ts was added as title #60
File 00913.m2ts was added as title #61
Title #00815.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00817.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00819.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00821.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00903.m2ts was added as title #62
Title #00905.m2ts has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00907.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00809.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00811.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00813.m2ts was added as title #63
Title #00915.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00823.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00825.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00927.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00827.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00917.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00919.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00921.m2ts was added as title #64
Title #00923.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00925.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00829.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00929.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00831.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00931.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00834.m2ts was added as title #65
Title #00932.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00270.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00630.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00631.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Video/A_Good_Day_to_Die_Hard
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00806.m2ts' at offset '445120512'
Failed to save title 1 to file D:/Video/A_Good_Day_to_Die_Hard/A_Good_Day_to_Die_Hard_t01.mkv
0 titles saved, 1 failed
ab1245
Re: Rip Failed - A Good Day to Die Hard
Post by ab1245 »
Debug log started at Sat Sep 21 02:14:50 2013 , written by MakeMKV v1.8.5 win(x64-release)
001005:0000 MakeMKV v1.8.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Moot/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=gduA9BjKdZ2vK+sSVFRbc1HIL3+sXX9sx6nZSbLOXZLYfEhQn7AG0SWTaTPYUZUkXpm4X3WEvNZw28PqxdVj7/nohcuEoGS3fztx7IPeegC/Eh2oDz1zLF7poOTsxFYnCQJTVK4TQpXlZ3GUGlOMcw+36v9zo912zg==
DCE=HUZgU4rpUq3sGK03j7MXOwuxT79xTgmi2utdNnudFm/jyDplox/OR7hdSkg2WnXNDWRvyFfRGZu4C6n+WCL0H9Y0+9kcTMNWQo/jeGaIRNBalpF1/+FZZEz0mIQ5BF19OkIr+hvoVrH4Qqhmqkr5AMHYr02lLDm2pw==
003317:0000 Loaded 32 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003322:0000 Processing BD+ code using disc-specific SVQ from builtin/dsall.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 53 clip(s)
DISCID=3ACDBB870DCA66B57DCCDA86E2DC4DB21C519F51
003025:0000 Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00341.mpls was added as title #0
003025:0000 Title #00012.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.mpls has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00800.mpls was added as title #1
003025:0000 Title #00300.mpls has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00301.mpls was added as title #2
003025:0000 Title #00302.mpls has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00303.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00304.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00305.mpls was added as title #3
003307:0000 File 00306.mpls was added as title #4
003307:0000 File 00307.mpls was added as title #5
003307:0000 File 00801.mpls was added as title #6
003307:0000 File 00326.mpls was added as title #7
003309:0000 Title 00850.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00802.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00852.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00851.mpls is equal to title 00801.mpls and was skipped
003025:0000 Title #00270.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00349.mpls was added as title #8
003307:0000 File 00350.mpls was added as title #9
003307:0000 File 00351.mpls was added as title #10
003025:0000 Title #00358.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00359.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00360.mpls has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00361.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00362.mpls has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00363.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00364.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00365.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00366.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00367.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00368.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00369.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00370.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00371.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00372.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00373.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00382.mpls was added as title #11
003307:0000 File 00311.mpls was added as title #12
003307:0000 File 00312.mpls was added as title #13
003307:0000 File 00313.mpls was added as title #14
003307:0000 File 00314.mpls was added as title #15
003307:0000 File 00315.mpls was added as title #16
003307:0000 File 00316.mpls was added as title #17
003307:0000 File 00317.mpls was added as title #18
003025:0000 Title #00318.mpls has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00320.mpls was added as title #19
003307:0000 File 00319.mpls was added as title #20
003307:0000 File 00321.mpls was added as title #21
003307:0000 File 00322.mpls was added as title #22
003307:0000 File 00323.mpls was added as title #23
003307:0000 File 00324.mpls was added as title #24
003307:0000 File 00615.mpls was added as title #25
003025:0000 Title #00630.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00632.mpls has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00613.mpls was added as title #26
003025:0000 Title #00618.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00617.mpls has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00619.mpls has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00620.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00616.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00621.mpls has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00614.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00631.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00633.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00637.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00634.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00635.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00638.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00636.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00629.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00612.mpls was added as title #27
003307:0000 File 00622.mpls was added as title #28
003025:0000 Title #00623.mpls has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00625.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00626.mpls has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00627.mpls was added as title #29
003025:0000 Title #00628.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00624.mpls was added as title #30
003025:0000 Title #00640.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00641.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00642.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00643.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00644.mpls has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00645.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00639.mpls was added as title #31
003307:0000 File 00376.mpls was added as title #32
003307:0000 File 00353.mpls was added as title #33
003025:0000 Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00200.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00601.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00280.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01288.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00281.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00282.m2ts has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00283.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00284.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00285.m2ts was added as title #34
003307:0000 File 00286.m2ts was added as title #35
003307:0000 File 00311.m2ts was added as title #36
003307:0000 File 00312.m2ts was added as title #37
003307:0000 File 00313.m2ts was added as title #38
003307:0000 File 00314.m2ts was added as title #39
003307:0000 File 00316.m2ts was added as title #40
003307:0000 File 00317.m2ts was added as title #41
003025:0000 Title #00318.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00319.m2ts was added as title #42
003307:0000 File 00320.m2ts was added as title #43
003307:0000 File 00321.m2ts was added as title #44
003307:0000 File 00322.m2ts was added as title #45
003307:0000 File 00324.m2ts was added as title #46
003307:0000 File 00325.m2ts was added as title #47
003307:0000 File 00342.m2ts was added as title #48
003307:0000 File 00343.m2ts was added as title #49
003307:0000 File 00344.m2ts was added as title #50
003307:0000 File 00350.m2ts was added as title #51
003307:0000 File 00351.m2ts was added as title #52
003307:0000 File 00352.m2ts was added as title #53
003025:0000 Title #00360.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00361.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00362.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00363.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00364.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00365.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00366.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00367.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00368.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00369.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00370.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00371.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00372.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00373.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00374.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00375.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00380.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00381.m2ts was added as title #54
003307:0000 File 00435.m2ts was added as title #55
003025:0000 Title #00490.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00315.m2ts was added as title #56
003307:0000 File 00323.m2ts was added as title #57
003025:0000 Title #01309.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01495.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01496.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01497.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01498.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01499.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01500.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01501.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01502.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01503.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01504.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01505.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01506.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01507.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01508.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01509.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01510.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01511.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01512.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01513.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01514.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01515.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01516.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01517.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01518.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01519.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01520.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01521.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01522.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01523.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01524.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01525.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01526.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01527.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01528.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01529.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01530.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01531.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01532.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01533.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01534.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01535.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01536.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01537.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01538.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01539.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01540.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01541.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01542.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01543.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01544.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01545.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01546.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01547.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01548.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01549.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01550.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01551.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01552.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01553.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01554.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01555.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01556.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01557.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01558.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01559.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01560.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01561.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01562.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01563.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01564.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01565.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01566.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01567.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01568.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01569.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01570.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01571.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01572.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01573.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01574.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01575.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01576.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01577.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01578.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01579.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01580.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01581.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01582.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01583.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01584.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01585.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01586.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01587.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01588.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01589.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01590.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01591.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01592.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01593.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01594.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01595.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01596.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01597.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01598.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01599.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01600.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01601.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01602.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01603.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01604.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01605.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01606.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01607.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01608.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01609.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01610.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01611.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01612.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01613.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01614.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01615.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01616.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01617.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01618.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01619.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01620.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01621.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01622.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01623.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01624.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01625.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01626.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01627.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01628.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01629.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01630.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01631.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01632.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01633.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01634.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01635.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01636.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01637.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01638.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01639.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01640.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01641.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01642.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01643.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01644.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01645.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01646.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01647.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01648.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01649.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01650.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01651.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01652.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01653.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01654.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01655.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01656.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01657.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01658.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01659.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01660.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01661.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01662.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01663.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01664.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01665.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01666.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01667.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01668.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01669.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01670.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01671.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01672.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01673.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01674.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01675.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01676.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01677.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01678.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01679.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01680.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01681.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01682.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01683.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01684.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01685.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01686.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01687.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01688.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01689.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01690.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01691.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01692.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01693.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01694.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01695.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01696.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01697.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01698.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01699.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01700.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01701.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01702.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01703.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01704.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01705.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01706.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00801.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00901.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00803.m2ts was added as title #58
003025:0000 Title #00805.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00807.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00909.m2ts was added as title #59
003307:0000 File 00911.m2ts was added as title #60
003307:0000 File 00913.m2ts was added as title #61
003025:0000 Title #00815.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00817.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00819.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00821.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00903.m2ts was added as title #62
003025:0000 Title #00905.m2ts has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00907.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00809.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00811.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00813.m2ts was added as title #63
003025:0000 Title #00915.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00823.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00825.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00927.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00827.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00917.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00919.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00921.m2ts was added as title #64
003025:0000 Title #00923.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00925.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00829.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00929.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00831.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00931.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00834.m2ts was added as title #65
003025:0000 Title #00932.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00270.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00630.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00631.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory D:/Video/A_Good_Day_to_Die_Hard
AV sync issues in D:/Video/A_Good_Day_to_Die_Hard/A_Good_Day_to_Die_Hard_t06.mkv
AV sync in 1 at 0:04:53.584 (4.375ms) : encountered overlapping frame, audio skew is +4.375ms
AV sync in 2,3 at 0:04:53.584 (15.041ms) : encountered overlapping frame, audio skew is +15.041ms
AV sync in 1 at 0:05:25.575 (9.708ms) : encountered overlapping frame, audio skew is +14.083ms
AV sync in 1 at 0:05:25.589 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +3.416ms
AV sync in 2,3 at 0:05:25.575 (9.708ms) : encountered overlapping frame, audio skew is +24.75ms
AV sync in 1 at 0:06:37.939 (9.375ms) : encountered overlapping frame, audio skew is +12.791ms
AV sync in 1 at 0:06:37.952 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +2.125ms
AV sync in 2,3 at 0:06:37.939 (20.041ms) : encountered overlapping frame, audio skew is +44.791ms
AV sync in 2,3 at 0:06:37.984 (32ms) : 1 frame(s) dropped to reduce audio skew to +12.791ms
AV sync in 1 at 0:09:36.242 (0.875ms) : encountered overlapping frame, audio skew is +3ms
AV sync in 2,3 at 0:09:36.242 (0.875ms) : encountered overlapping frame, audio skew is +13.666ms
AV sync in 1 at 0:12:00.219 (1.5ms) : encountered overlapping frame, audio skew is +4.5ms
AV sync in 2,3 at 0:12:00.219 (22.833ms) : encountered overlapping frame, audio skew is +36.5ms
AV sync in 2,3 at 0:12:00.256 (32ms) : 1 frame(s) dropped to reduce audio skew to +4.5ms
AV sync in 1 at 0:13:56.836 (2.166ms) : encountered overlapping frame, audio skew is +6.666ms
AV sync in 2,3 at 0:13:56.836 (23.5ms) : encountered overlapping frame, audio skew is +28ms
001003:0020 DEBUG: Code 3221225628 at ^lI\~8&p6,_cdN'VR=$wA*mT^:121263521
001003:0020 DEBUG: Code 3221225628 at Ym%b"z6uUTBDDpud:29393953
001003:0020 DEBUG: Code 2 at Y88FR*My~:C+m1Uu:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00806.m2ts' at offset '442497024'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00806.m2ts' at offset '442503168'
001003:0020 DEBUG: Code 0 at 4E=K]x-jYWhk;*&n+V&j:121262739
001003:0020 DEBUG: Code 0 at <:[}Wfm2Jp0@X.X_ML"I:121261888
001003:0020 DEBUG: Code 0 at 4E=K]x-jYWhk;*&n+V&j:213130743
001003:0020 DEBUG: Code 216066 at 4E=K]x-jYWhk;*&n+V&j:29393332
001003:0020 DEBUG: Code 0 at aQz@ofj}|gB~qlTc:c}Y3:29398645
005003:0000 Failed to save title 6 to file D:/Video/A_Good_Day_to_Die_Hard/A_Good_Day_to_Die_Hard_t06.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat Sep 21 02:30:15 2013
Disk can't be read at certain parts. Could be dirt, scratches, or a problem with the mastering on the disk.
Everything else seems to indicate the disk is being processed properly, up to the point of hitting the hard error.
