Recommended Way to Convert VC1 MKV to H264 MKV?
Charlie97l
#1 Post by Charlie97l » Wed Sep 18, 2013 6:30 pm
I have several HDDVD rips (and a few BD) that are VC1. Those won't play well on my HTPCs (Raspberry Pi and Acer Revo 1600) running XBMC.
Any suggestions would be appreciated. I know it's not possible to do a 1:1 conversion, but as close to that as possible would be ideal.
Smithcraft
Re: Recommended Way to Convert VC1 MKV to H264 MKV?
#2 Post by Smithcraft » Thu Sep 19, 2013 10:33 am
If they are interlaced VC1 then you need to get something that transcodes interlaced VC1.
If it's just regular VC1 then Handbrake would be fine.
SC
Romansh
#3 Post by Romansh » Thu Sep 19, 2013 3:36 pm
Update to a bleeding-edge version of XBMC? If they use the latest libavcodec, interlaced VC-1 should work fine.
Or find a way to use hardware-accelerated decoding on the Pi (don't know whether it's possible, TBH).
XBMC forums could help with that.
