Bug. Multiple runs at once switches drives
philhu
Post by philhu »
If I run makemkv multiple times using multiple DVD drives, the different runs each reads the drive statuses as they switch between drives on their own
Example. Run it twice. Point one to drive1 and one to drive2. Then insert a disk in drive1. BOTH runs will switch to drive1
This is very confusing at times
It does not switch while it is writing mkv files. Which is good
philhu
Re: Bug. Multiple runs at once switches drives
Post by philhu »
Does anyone else see this? It is a great program, but this problem can be very annoying
It isn't a bug, so much as a lacked feature - locking an instance of MakeMKV to a single optical drive. Since MakeMKV will attempt to use any optical drives it finds, multiple copies running at the same time think the "other instance's drive" is fair game.
It's one of the more requested features to add.
