encode multiple subtitle tracks
joshsmoore
Post by joshsmoore » Wed Sep 18, 2013 12:47 am
I am using makemkv to rip several blu-rays that have both foreign language scenes (so forced English subtitles) and a separate Chinese subtitle track that I want to include in the end file, as a selectable subtitle, not burnt in. So when I rip it with makemkv I select force only for the English subtitiles, it for the Chinese subtitles I un select force only. Then I make the mkv and dump it into handbrake for encoding so I can play it n my apple devices. The problem is that I can only add 1 subtitle track and it must be burned in. So I either get the English subtitles for the firing language scenes or I get the Chinese subtitles (burned in and not selectable). When I try to add them both I get an error message. Is there any way for me to add both and have the Chinese subtitles selectable not burned in?
Thanks,
Josh
P.S. I am not sure if this is a makemkv problem or handbrake issue so I placed the question on both boards.
angelgraves13
Re: encode multiple subtitle tracks
Post by angelgraves13 » Wed Sep 18, 2013 1:37 am
Why not just use Handbrake to make the video smaller and then add the subtitles back in with mkvmerge.
Better yet, just keep the remux.
Chetwood
Post by Chetwood » Wed Sep 18, 2013 5:41 am
It's a Handbrake problem (or rather a problem with the container you use on your Apple).
