issue playing an MKV AVC/DTS on samsung blu ray player
aaryan.varun
Post by aaryan.varun »
i have the same bluray player.
owning it for past 2 months.
serves all the basic purposes, but as you can see the specs it only decodes the daolby standards(DD, DDplus, DDtruehd) but doesnt decode the DTS standards, rather it provides you with bitstreaming output for the DTS.
but that doesnt matter much as my receiver decodes DTS for me.
now the problem i faced was when i played this file:
File size : 10.0 GiB
Duration : 2h 10mn
Overall bit rate : 11.0 Mbps
Encoded date : UTC 2010-02-22 21:41:31
Writing application : mkvmerge v5.9.0 ('On The Loose') built on Dec 9 2012 15:37:01
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 10mn
Bit rate : 9 500 Kbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.258
Stream size : 8.46 GiB (84%)
Title : Iron.Man.3.2013
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 10mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.38 GiB (14%)
Title : DTS-CORE 1536K ENG
Language : English
Default : Yes
Forced : No
now as you can see its a heavy file. With really high video and sound bit rates.
the problem is whenever i seek this movie forward and reverse or fast forwarding/reversing or use the jump tool
the movie freezes, sometimes the play resumes after being unresponsive for some time or the movie is interrupted and it exits to the main menu of the player. And this only happens when i fast forward/reverse the movie.
rest everything works fully fine!
IF ANYBODY IS FACING THE SAME PROBLEM. PLEASE LET ME KNOW IF YOU'VE FOUND ANY SOLUTION TO IT?
angelgraves13
Re: issue playing an MKV AVC/DTS on samsung blu ray player
Post by angelgraves13 »
I wouldn't call 11MB/s heavy.
I play 35MB/s remuxes on my WD TV Live and they play fine.
