Last King of Scotland
Locked
overclock
Post by overclock »
wtf? this doesn't work for me. log attached.
setarip_old
Re: Last King of Scotland
Post by setarip_old »
Hi!
Is there a reason you didn't submit the dump to: svq@makemkv.com ?
overclock
Post by overclock »
sent.
setarip_old
Based on your screen name I'll ask - Is your system overclocked?
If so, that may be the cause of your problem...
AvAyA
Post by AvAyA »
overclock wrote:wtf? this doesn't work for me. log attached.
@overclock;
same problem here with scotland. Log File enclosed
--AvAyA
setarip_old
@AvAyA
Hi!
skaterboi
Post by skaterboi »
@setarip_old:
same thing goes 4 me to:
Debug log started at Tue Feb 02 20:41:34 2010 , written by MakeMKV v1.4.11 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.11 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Sean/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003326:000000:0000 Loaded 1 SVQ file(s)
003334:000000:0000 Processing BD+ code, please be patient - this may take up to few minutes
003332:000000:0000 Processing BD+ code using generic SVQ from allcombo.svq
001012:000000:0020 DEBUG: Code 0 at Tappane}-anFFptW:213133457
001012:000000:0020 DEBUG: Code 0 at Tappane}-anFFptW:121263061
001012:000000:0020 DEBUG: Code 0 at Tappane}-anFFptW:29398415
003333:000000:0000 Failed to process BD+ code using generic SVQ from allcombo.svq
001012:000000:0020 DEBUG: Code 0 at O:4B^/!d\_gUV8"DU+Er@:213133250
003341:000000:0000 Saved BD+ dump file as C:/Seans_Playhouse/dump_The_Last_King_of_Scotland_7D395FE1D82AD3E4.tgz
003329:000000:0000 Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
001012:000000:0020 DEBUG: Code 0 at s3T6@\rX=d* 9h:rquK:213132721
005010:000000:0000 Failed to open disc
Application exited at Tue Feb 02 20:43:04 2010
skaterboi
Post by skaterboi »
updated to 1.4.12 still doesnt work
Debug log started at Tue Feb 02 23:43:27 2010 , written by MakeMKV v1.4.12 beta win(x86-release)
001005:0000 MakeMKV v1.4.12 beta win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Sean/MakeMKV_log.txt
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
003317:0000 Loaded 1 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from allcombo.svq
001003:0020 DEBUG: Code 0 at qI@wuPlTIK&'-z5B:213133457
001003:0020 DEBUG: Code 0 at qI@wuPlTIK&'-z5B:121263061
001003:0020 DEBUG: Code 0 at qI@wuPlTIK&'-z5B:29398415
003325:0000 Failed to process BD+ code using generic SVQ from allcombo.svq
001003:0020 DEBUG: Code 0 at (;*S6_MwIPa6ne(0+t~]9:213133250
003332:0000 Saved BD+ dump file as C:/Seans_Playhouse/dump_The_Last_King_of_Scotland_7D395FE1D82AD3E4.tgz
003321:0000 Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
001003:0020 DEBUG: Code 0 at M\"hnm_^tUjf"c%Bj{u:213133411
Post by mike admin »
Plaese check back with viewtopic.php?f=1&t=949
Locked
