Output Size
clotje
Output Size
Post by clotje »
Nice software you made here, it very fast and correct.
But can you made in the next release, that we can choose the output size? Like VBR or CQ
Thanks,
Clotje
Post by mike admin »
Hello.
MakeMKV does not change audio/video data during conversion at all. Therefore it is impossible to change output size since it is determined by input size. However it is always possible to re-encode MKV with different parameters and there are many free tools to do just that.
estugarda
Post by estugarda »
Which software can re-encode (let's say compress to h264 or xvid) MKV file made with MakeMKV?
DaOptika
Post by DaOptika »
That would be MeGUI together with many other tools - and that would be hell of a lot more work to do and would take you about 20h/movie depending on your system.
estugarda
Post by estugarda »
MeGUI needs avisynt (avs) file. That means it needs a DVD to. I asked how can one reencode already encoded MKV. I want exactly the same structure of MKV file like one made with MakeMKV, only with compressed video instead of MPEG2.
sallermas
Post by sallermas »
AutoMKV is what you need, readily availble for download.
estugarda
Post by estugarda »
Unfortunately AutoMKV acts on all my computers like on big bug. Crashing and breaking up all the time from various reasons. Sometimes without any notification. Ususally it gives that bumbing sound and doesn't even start to reencode. Also, accordcing to the menus, it supports only up to 2 audio tracks. This is not a working solution for my case. Still on the search.
Homer
Re:
Post by Homer »
mike admin wrote: MakeMKV does not change audio/video data during conversion at all. Therefore it is impossible to change output size since it is determined by input size. However it is always possible to re-encode MKV with different parameters and there are many free tools to do just that.
will it be a part of the program in the future ? or is there a technical reason why it may not ?
it would be great if we could make some of the 10+gb files smaller, maybe to fit on a dvd-9 disc ?? (i understand that this means some quality loss)
thanks,
§ Pimp of Mario's World.. Hater of Society. §
