Did I miss this?
Every disk I use requires that I uncheck 'Subtitles' for each Title.
I never use them. Can there be a preference to always uncheck unforced subtitles?
Thank you
Request: Preferences to turn off (nonforced) subtitle always
Re: Request: Preferences to turn off (nonforced) subtitle al
Not a preference, but... if you get into using advanced profiles (there's a section here about them), you can do it.
- Contact:
No, default selection rule can be overwritten in preferences. Just add ",-sel:(subtitle&(!forced))" to default track selection string in preferences.Woodstock wrote:Not a preference, but... if you get into using advanced profiles (there's a section here about them), you can do it.
That worked!!!!
Thank you so much!
Thank you so much!
