Homeland Season 2
Homeland Season 2
I seemed to be able to convert disc 1 successfully, but on playback there are considerable artifacts constantly -- stretching, blurring, distortion.
It played back fine though the ol' player (*after* yet another cumbersome update -- actually everything to do with playing physical discs is cumbersome which is why I got MakeMKV.)
I updated MakeMKV to the latest of course.
Is this just some new protection technique so I just need to wait for an MVK update? Anything I can do to speed up that update?
Re: Homeland Season 2
Was the source a bluray, or DVD? (can't take for granted that it's a BD, just because you posted here... )
There are certain CODECs found on BDs that a lot of players cannot decode.
This is what I get:
MakeMKV v1.8.4 win(x64-release) started
Loaded 262 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as C:\Users\ArieS/.MakeMKV/dump_Homeland__Season_2_Disc_1_60200CCA527A1D1D.tgz
BD+ code processed but no FUTs were obtained, errors may follow
Title #00720.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
As iseeisee has said, I can copy the BD but the playback has a lot of artifacts.
Have you forwarded the TGZ file to svq@makemkv.com yet? Once Mike can analyze it, a new SVQ file can be created to deal with the BD+.ArieS wrote:Processing BD+ code, please be patient - this may take up to few minutes
Same problem here. The disk rips but there are lots of artifacts on playback. Playback of original disc in a BD player does not exhibit the artifact problem.
I expect that this is some new protection scheme, hopefully can be worked around.
As a test I'm going to re-rip on my Windows virtual machine and see if after the disc is decrypted by Any-DVD there is still a problem.
I decrypted the disk to an ISO with AnyDVD-HD and then ripped it with MakeMKV and it's working fine, so definitely an encryption issue with whatever security is being used.
If I get a chance in a bit I will go ahead and dump the needed data and report it as a disc problem.
Optical drive "BD-ROM HL-DT-ST BD-RE UH10LS20 1.00" opened in DASPI v1.3 mode.
Loaded 243 SVQ file(s)
Saved BD+ dump file as /Users/Jason/.MakeMKV/dump_Homeland__Season_2_Disc_1_94201C7B497D264C.tgz
Use something like Yousendit (now Hightail) https://www.hightail.com/voip-ninja wrote:I grabbed the tgz file but none of my five email accounts can handle a 50+ MB attachment, so I can't send it.Code: Select all
Optical drive "BD-ROM HL-DT-ST BD-RE UH10LS20 1.00" opened in DASPI v1.3 mode. Using direct disc access mode Loaded 243 SVQ file(s) Processing BD+ code, please be patient - this may take up to few minutes Processing BD+ code using generic SVQ from builtin/00000.svq Saved BD+ dump file as /Users/Jason/.MakeMKV/dump_Homeland__Season_2_Disc_1_94201C7B497D264C.tgz BD+ code processed but no FUTs were obtained, errors may follow
I did, yes.Woodstock wrote:Have you forwarded the TGZ file to svq@makemkv.com yet? Once Mike can analyze it, a new SVQ file can be created to deal with the BD+.ArieS wrote:Processing BD+ code, please be patient - this may take up to few minutes
I did that and it worked as well. Thanks for the workaround voip-ninja!voip-ninja wrote:I decrypted the disk to an ISO with AnyDVD-HD and then ripped it with MakeMKV and it's working fine, so definitely an encryption issue with whatever security is being used.
Any DVD is usually very fast to update and tends to be my backup method if MakeMKV can't handle a disc. I do love MakeMKV enough to have registered it though (sure beats the piss out of Clown-BD).
Yes, the size of emails can be an issue... There are alternative methods for getting the file to Mike, though.
If you don't have your own server to host it (it's a nice luxury), there are services like Dropbox and similar where you can upload the file, then send the link to Mike at svq@makemkv.com for review.
Good point I had not thought of that. Sounds like someone else sent it to him already.Woodstock wrote:Yes, the size of emails can be an issue... There are alternative methods for getting the file to Mike, though.
- Contact:
SVQ updated, but we only got dump for disc1.
