TRUEHD AUDIO
samccfl99
TRUEHD AUDIO
#1 Post by samccfl99 » Thu Sep 12, 2013 5:19 am
will this ever work from a bluray input? it is the best audio and it is being used more and more. who wants to watch a bluray in regular crappy dolby? thank you.?
Re: TRUEHD AUDIO
#2 Post by Woodstock » Thu Sep 12, 2013 12:50 pm
Support for THD is dependent upon your player - which is why they provide a more compatible soundtrack in addition to THD, and why MakeMKV has the FLAC profile, to convert it to a more compatible format, if your player doesn't support THD.
samccfl99
Re: TRUEHD AUDIO
#3 Post by samccfl99 » Thu Sep 12, 2013 1:06 pm
Woodstock wrote:Support for THD is dependent upon your player - which is why they provide a more compatible soundtrack in addition to THD, and why MakeMKV has the FLAC profile, to convert it to a more compatible format, if your player doesn't support THD.
well i do not know what all the makemkv program does, but i only use it to convert an original bluray to mkv and then input the mkv to tsmuxer to create another bluray. in tsmuxer it throws out the truehd track. now i do not even know if when i only output the truehd kmv track if it will play ok on my sony bluray thru the usb stick. my sony bpd-s390 will play mkv files from the usb, but not from the dlna because the player does not support mkv thru dlna even when i run it thru messizmo. when using windows media the bluray does not even see the mkv files, but it does with messizmo, but when i try to play it, it says file corrupt. since i dont know how to isolate one chapter and convert it, i cant test it because i dont have a stick big enough to fit a movie mkv file. does any of this make sense to anyone? thanks
angelgraves13
Re: TRUEHD AUDIO
#4 Post by angelgraves13 » Thu Sep 12, 2013 5:57 pm
MakeMKV doesn't re-encode the track, it just copies it into the MKV container.
If your player doesn't support it, then it doesn't support it.
I'd recommend a WD TV Live as it plays everything.
NodNarb012
Re: TRUEHD AUDIO
#5 Post by NodNarb012 » Fri Sep 13, 2013 12:30 am
angelgraves13 wrote:MakeMKV doesn't re-encode the track, it just copies it into the MKV container.
The latest WD TV Live is a very good media player for the money, but it doesn't play everything. The prime example being DTS-HD.
Chetwood
Re: TRUEHD AUDIO
#6 Post by Chetwood » Fri Sep 13, 2013 4:43 am
Right, it 'only' plays the core but the questions here is why bother with MKV when the end format ist Blu-Ray?
necrosis
Re: TRUEHD AUDIO
#7 Post by necrosis » Fri Sep 27, 2013 1:26 am
MKV is a container not a codec.
Chetwood
Re: TRUEHD AUDIO
#8 Post by Chetwood » Fri Sep 27, 2013 7:19 am
You don't say. Still doesn't explain this workflow:
samccfl99 wrote:well i do not know what all the makemkv program does, but i only use it to convert an original bluray to mkv and then input the mkv to tsmuxer to create another bluray.
