error with home made dvd, and debug codes
unaltro
Post by unaltro » Wed Sep 11, 2013 7:00 am
I have a folder containing the files of a DVD that was made from a tv recording, maybe PVR. Converting the folder with MakeMKV produces the following dump:
Calculated BUP offset for VTS #1 does not match one in IFO header.
Title #1 was added (5 cell(s), 1:27:44)
Saving 1 titles into directory F:/movies/mkv
DEBUG: Code 149 at zH6S?E5K85!+n7Kw98h:29399243
DEBUG: Code 0 at zH6S?E5K85!+n7Kw98h:121262417
DEBUG: Code 0 at zH6S?E5K85!+n7Kw98h:121262210
DEBUG: Code 0 at vKB(dGEhkkgO}MEm^zu\*:29398369
DEBUG: Code 0 at vKB(dGEhkkgO}MEm^zu\*:121266925
DEBUG: Code 0 at Fca}T$fvmI`2k!Vs`*=:213130697
DEBUG: Code 0 at Fca}T$fvmI`2k!Vs`*=:121263958
DEBUG: Code 0 at Fca}T$fvmI`2k!Vs`*=:213131801
DEBUG: Code 0 at Fca}T$fvmI`2k!Vs`*=:29397564
DEBUG: Code 0 at 0i!pg~/_9"P,n'w;:213130122
DEBUG: Code 0 at vKB(dGEhkkgO}MEm^zu\*:29398645
DEBUG: Code 0 at u=Y2U\&>hJS4=wQQHa:121266580
DEBUG: Code 0 at u=Y2U\&>hJS4=wQQHa:29399059
Failed to save title 0 to file F:/movies/mkv/title00.mkv
0 titles saved, 1 failed
If I understand correctly, the only error is the first 149 code. While I would like to be able to convert the disk with makeMKV, my question is actually different: is there a way (for the user), e.g. in a help file, to understand from the error codes what kind of error makeMKV is detecting? Since, if the error is in the video, with a hint on the kind of error I could try to use e.g. avidemux or something similar and correct/convert the video anyway. I searched the website but didn't find anything on the meaning of debug errors.
mkv.zip
(627.13 KiB) Downloaded 505 times
Re: error with home made dvd, and debug codes
Post by mike admin » Tue Sep 17, 2013 8:26 am
This error means that the video stream is incorrect. MakeMKV usually can work around, but not this time. Please produce and submit a testdump for this title per instructions at /onlinehelp/testdump.html
unaltro
Post by unaltro » Fri Sep 27, 2013 7:48 am
I sent the dump link by mail some days ago. In the meantime, I see that I have several DVDs, all made with the same tools, that show the same errors sequence. So I suspect that the error may be in something added while creating the DVD from the movie file, e.g. the title track, or some part of the dvd that is not the main track anyway. This makes me think at something that may be a feature request/suggestion: if there is an error in a track, does makemkv go on with the remaining tracks, or does it just stop?
unaltro
Post by unaltro » Mon Nov 11, 2013 10:24 am
I downloaded MakeMKV 1.8.6, now i get a 449 error instead of 149, but the behaviour seems to be the same. Should I send a dump, or are these files hopeless?
Post by mike admin » Tue Nov 12, 2013 3:57 am
Unfortunately its the latter. The problem is that the video stream is very broken - it has a lot (really) of missing frames (sometimes 3 frames per GOP). You may try making a MKV file by hand with MKVtoolnix, but you'll likely end up with an unplayable file as well.
unaltro
Post by unaltro » Wed Nov 13, 2013 9:57 am
Ok, thank you anyway :) BTW, I managed to build a mkv with avidemux in "copy mode". VLC plays it, but VLC is probably very resilient to errors ;)
Thanks again for the good job
