Hello all:
New to this forum, and appreciate any help you might have to offer. I'm using MakeMKV 1.8.4 on an iMac running OS X 10.8.4. When I try to pull files off the blu-ray for It's Always Sunny Season 8, Make MKV appears to do so without any problem. However, the MKV file is very badly digitized and distorted when I attempt to view it, almost as if it wasn't fully decoded. I've pasted the dialog from Make MKV below. Thanks for your help.
MakeMKV v1.8.4 darwin(x86-release) started
Optical drive "DVD+R-DL HL-DT-ST DVDRAM GSA-5163D A104d" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BP06LU10 HL03d" opened in OS access mode.
Loaded 263 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /Users/Reeveseye/.MakeMKV/dump_It_s_Always_Sunny_in_Philadelphia__Season_8__Disc_1_EEF01A06D2F3F256.tgz
BD+ code processed but no FUTs were obtained, errors may follow
Title #00720.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
File 00802.mpls was added as title #2
File 00803.mpls was added as title #3
File 00804.mpls was added as title #4
File 00001.mpls was added as title #5
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00801.mpls and was skipped
Title 00852.mpls is equal to title 00802.mpls and was skipped
Title 00853.mpls is equal to title 00803.mpls and was skipped
Title 00854.mpls is equal to title 00804.mpls and was skipped
File 00855.mpls was added as title #6
Title 00805.mpls is equal to title 00855.mpls and was skipped
Title #00019.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00450.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00451.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/Reeveseye/Workspace/m2ts
Forced subtitles track #4 turned out to be empty and was removed from output file
1 titles saved
It's Always Sunny in Philadelphia Season 8
Re: It's Always Sunny in Philadelphia Season 8
Have you forwarded the generated file to svq@makemkv.com for analysis?Saved BD+ dump file as /Users/Reeveseye/.MakeMKV/dump_It_s_Always_Sunny_in_Philadelphia__Season_8__Disc_1_EEF01A06D2F3F256.tgz
Reeveseye
I have not. Where do I find the file?
The debug output says it was saved as /Users/Reeveseye/.MakeMKV/dump_It_s_Always_Sunny_in_Philadelphia__Season_8__Disc_1_EEF01A06D2F3F256.tgz on your drive, so it should be fairly easy to find... Assuming the operating system doesn't "help" you by hiding things in your home directory.
(Yes, it seems stupid, but I have run into such restrictions on just about any operating system that understands the idea of a "home directory")
SVQ updated.
