Now You See Me DVD
MakOwner
Now You See Me DVD
#1 Post by MakOwner » Sat Sep 07, 2013 8:07 pm
This is stil in the drive ripping, so I'm sure there will be more ... dvdbackup that relies on decss2 also fails but with different messages and goes into a loop that slolwy consumes all CPU until the host is unresponsive.
Edit: MakeMkv has the same issue - it apparently reads the disc in a loop until the system becomes unresponsive.
MakeMKV v1.8.4 linux(x64-release) started
Debug logging enabled, log will be saved as /home/dale/MakeMKV_log.txt
Title #2 was added (2 cell(s), 0:15:37)
Title #3 was added (2 cell(s), 0:02:25)
Title #4 has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 was added (2 cell(s), 0:02:10)
Title #8 was added (2 cell(s), 0:02:26)
Title #9 was added (2 cell(s), 0:02:26)
Title #10 has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 was added (2 cell(s), 0:02:31)
Title #12 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 was added (1 cell(s), 0:25:05)
Cells 19-end were skipped due to cell commands (structure protection?)
Title #21 was added (17 cell(s), 1:55:06)
Title #22 was added (18 cell(s), 1:55:07)
Title #23 was added (18 cell(s), 1:55:07)
Title #24 was added (26 cell(s), 2:02:14)
Title #25 was added (26 cell(s), 2:02:14)
Title #26 was added (18 cell(s), 1:55:07)
Title #27 was added (26 cell(s), 2:02:14)
Title #28 was added (18 cell(s), 1:55:07)
Title #29 was added (18 cell(s), 1:55:07)
Title #31 was added (25 cell(s), 2:01:49)
Title 1 in VTS 22 is equal to title 1 and was skipped
Title 1 in VTS 24 is equal to title 1 and was skipped
Saving 11 titles into directory /home/dale/Videos/Now_You_See_Me
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_17_1.VOB' at offset '17637376'
DEBUG: Code 0 at :D-}(kQ7#2R7=/;l0P;/:121262739
DEBUG: Code 0 at k(p.S5tj0`/yS/_bZ|v:121261681
DEBUG: Code 0 at :D-}(kQ7#2R7=/;l0P;/:213130743
DEBUG: Code 8612 at :D-}(kQ7#2R7=/;l0P;/:29393332
DEBUG: Code 0 at <ES3ug^"YY#[u:Da8iVzp:29398645
DEBUG: Code 0 at +xE`v0gm?KC2V=i:_^#:213132744
DEBUG: Code 0 at FN${p..c&S9#7p_Pn:121263728
DEBUG: Code 0 at FN${p..c&S9#7p_Pn:121263176
DEBUG: Code 0 at FN${p..c&S9#7p_Pn:29393930
Failed to save title 6 to file /home/dale/Videos/Now_You_See_Me/Now_You_See_Me_t06.mkv
MakOwner
Re: Now You See Me DVD
#2 Post by MakOwner » Sun Sep 08, 2013 1:05 am
Two diffierent PCs, two different BD drives, same results.
Took the disc back and had it replaced, and I'm seeing the same errors.
rwbrahm
#3 Post by rwbrahm » Sun Sep 08, 2013 1:58 pm
Just wanted to give my experience. I had no issues and I am backing up the DVD version.
I just got my copy and literally just started to back it up with MakeMKV.
Here is the log.
MakeMKV v1.7.9 win(x64-release) started
The new version 1.8.4 is available for download at /download
Title #0 was added (25 cell(s), 1:57:37)
Title #1 was added (2 cell(s), 0:02:26)
Title #2 was added (2 cell(s), 0:02:26)
Title #3 has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 was added (2 cell(s), 0:02:31)
Title #5 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 was added (1 cell(s), 0:27:00)
Title #10 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 was added (17 cell(s), 1:55:08)
Title #14 was added (17 cell(s), 1:55:08)
Title #15 was added (17 cell(s), 1:55:08)
Title #16 was added (25 cell(s), 1:57:37)
Title #17 was added (17 cell(s), 1:55:08)
Title #19 was added (17 cell(s), 1:55:08)
Cells 18-end were skipped due to cell commands (structure protection?)
Title #21 was added (16 cell(s), 1:55:07)
Title #22 was added (25 cell(s), 1:57:37)
Title #23 was added (24 cell(s), 1:57:12)
Title 1 in VTS 14 is equal to title 1 and was skipped
Now I'm looking at four potential video segments(Attached image).
So now I have to sort through the four versions and figure out which one is legit.
I will post an update when I figure that out.
-Rick
MakOwner
#4 Post by MakOwner » Sun Sep 08, 2013 2:24 pm
I get consistent failures over VTS_17_1.VOB, 24_1.VOB and 01_1.VOB. Title 6. 9 and 10 fail to save.
I have tried this one two LG BD burner drives -- the older, slower one is region set in region 1, the newer faster one is not yet region set.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_17_1.VOB' at offset '17637376'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_24_1.VOB' at offset '55296'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_24_1.VOB' at offset '14954496'
Failed to save title 9 to file /home/dale/Videos/Now_You_See_Me/Now_You_See_Me_t09.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '25980928'
Failed to save title 10 to file /home/dale/Videos/Now_You_See_Me/Now_You_See_Me_t10.mkv
8 titles saved, 3 failed
rwbrahm
#5 Post by rwbrahm » Sun Sep 08, 2013 2:49 pm
So MakeMKV just finished backing up my disc.
It was able to back up two of the four titles.
Source title ID:1 and 22 both failed and 14 and 24 completed successfully.
Now I will sit down and watch both of those and see if I can figure out which one is legit.
Here is the log if you are interested.
Saving 4 titles into directory G:/Movies/Now_You_See_Me
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9252864, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9254912, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9256960, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9259008, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9261056, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9263104, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9265152, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9267200, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9269248, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9271296, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9273344, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9275392, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9277440, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9279488, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9281536, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9283584, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9285632, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9287680, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9289728, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9291776, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9293824, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9295872, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9297920, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9299968, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9302016, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9304064, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9306112, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9308160, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9310208, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9312256, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9314304, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9316352, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9318400, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9320448, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9322496, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9324544, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9326592, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9328640, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9330688, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9332736, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9334784, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9336832, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9338880, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9340928, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9342976, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9345024, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9347072, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9349120, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9351168, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9353216, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9355264, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9357312, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9359360, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9361408, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9363456, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9365504, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9367552, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9369600, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9371648, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9373696, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9375744, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9377792, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9379840, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9381888, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9383936, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9385984, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9388032, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9390080, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9392128, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9394176, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9396224, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9398272, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9400320, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9402368, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9404416, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9406464, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9408512, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9410560, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9412608, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9414656, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9416704, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9418752, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9420800, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9422848, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9424896, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9426944, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9428992, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9431040, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9433088, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9435136, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9437184, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9439232, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9441280, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9443328, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9445376, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9447424, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9449472, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9451520, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9453568, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9455616, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9457664, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9459712, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9461760, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9463808, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9465856, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9467904, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9469952, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9472000, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9474048, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9476096, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9478144, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9480192, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9482240, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9484288, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9486336, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9488384, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9490432, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9492480, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9494528, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9496576, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9498624, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9500672, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9502720, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9504768, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9506816, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9508864, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9510912, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9512960, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9711616, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9713664, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9715712, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9717760, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9719808, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9721856, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9723904, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9725952, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9728000, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9730048, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9732096, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9734144, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9736192, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9738240, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9740288, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9742336, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9744384, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9746432, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9748480, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9750528, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9752576, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9754624, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9756672, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9758720, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9760768, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9762816, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9764864, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9766912, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9768960, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9771008, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9773056, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9775104, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9777152, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9779200, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9781248, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9783296, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9785344, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9787392, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9789440, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9791488, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9793536, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9795584, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9797632, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9799680, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9801728, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9803776, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9805824, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9807872, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9586688, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9588736, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9590784, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9592832, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9594880, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9596928, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9598976, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9601024, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9603072, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9605120, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9607168, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9609216, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9611264, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9613312, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9615360, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9617408, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9619456, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9621504, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9623552, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9625600, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9627648, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9629696, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9631744, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9633792, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9635840, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9637888, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9639936, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9641984, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9644032, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9646080, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9648128, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9650176, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9652224, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9654272, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9656320, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9658368, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9660416, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9662464, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9664512, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9666560, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9668608, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9670656, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9672704, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9674752, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9676800, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9678848, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9680896, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9682944, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9684992, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9687040, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9689088, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9691136, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9693184, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9695232, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9697280, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9699328, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9701376, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9703424, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9705472, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9707520, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9709568, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9809920, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9811968, attempting to work around
The source file '/VIDEO_TS/VTS_22_1.VOB' is corrupt or invalid at offset 9814016, attempting to work around
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/VIDEO_TS/VTS_22_1.VOB' at offset '9816064'
Failed to save title 0 to file G:/Movies/Now_You_See_Me/Now_You_See_Me_t00.mkv
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16797696, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16799744, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16801792, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16803840, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16805888, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16807936, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16809984, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16812032, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16814080, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16816128, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16818176, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16820224, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16822272, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16824320, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16826368, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16828416, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16830464, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16832512, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16834560, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16836608, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16838656, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16840704, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16842752, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16844800, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16846848, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16848896, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16850944, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16852992, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16855040, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16857088, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16859136, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16861184, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16863232, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16865280, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16867328, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16869376, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16871424, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16873472, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16875520, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16877568, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16879616, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16881664, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16883712, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16885760, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16887808, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16889856, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16891904, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16893952, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16896000, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16898048, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16900096, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16902144, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16904192, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16906240, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16908288, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16910336, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16912384, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16914432, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16916480, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16918528, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16920576, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16922624, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16924672, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16926720, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16928768, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16930816, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16932864, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16934912, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16936960, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16939008, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16941056, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16943104, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16945152, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16947200, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16949248, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16951296, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16953344, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16955392, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16957440, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16959488, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16961536, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16963584, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16965632, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16967680, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16969728, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16971776, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16973824, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16975872, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16977920, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16979968, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16982016, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16984064, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16986112, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16988160, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16990208, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16992256, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16994304, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16996352, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16998400, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17000448, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17002496, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17004544, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17006592, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17008640, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17010688, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17012736, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17014784, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17016832, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17018880, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17020928, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17022976, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17025024, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17027072, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17029120, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17031168, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17033216, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17035264, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17037312, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17039360, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17041408, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17043456, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17045504, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17047552, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17049600, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17051648, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17053696, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17055744, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17057792, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17256448, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17258496, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17260544, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17262592, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17264640, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17266688, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17268736, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17270784, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17272832, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17274880, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17276928, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17278976, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17281024, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17283072, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17285120, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17287168, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17289216, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17291264, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17293312, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17295360, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17297408, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17299456, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17301504, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17303552, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17305600, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17307648, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17309696, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17311744, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17313792, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17315840, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17317888, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17319936, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17321984, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17324032, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17326080, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17328128, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17330176, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17332224, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17334272, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17336320, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17338368, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17340416, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17342464, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17344512, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17346560, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17348608, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17350656, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 17352704, attempting to work around
Failed to save title 7 to file G:/Movies/Now_You_See_Me/Now_You_See_Me_t07.mkv
2 titles saved, 2 failed
-Rick
MakOwner
#6 Post by MakOwner » Sun Sep 08, 2013 3:27 pm
rwbrahm wrote:So MakeMKV just finished backing up my disc.
-Rick
Mine eventually spit some stuff out that I have to go through tonight.
rwbrahm
#7 Post by rwbrahm » Sun Sep 08, 2013 9:56 pm
Source Title ID:1 was the winner for me.
MakOwner
#8 Post by MakOwner » Sun Sep 08, 2013 11:04 pm
Title 7 and 8 copied out for me -- boith are pretty close to the same size, I'll have to watch each to figure out which is good.
Wish I could meet the ..gentlemen... responsible for coding this corruption on the discs like that.
I'm sure a few well placed strokes of encouragement would do them well.
