How do you disable subtitles?
Just tried out this program and I am very impressed, so quick and easy, but I just cannot find the way to disable the subtitles?
Disable Subtitles?
Re: Disable Subtitles?
You can tell MakeMKV to not include the subtitles when it rips, or you can use tools like MKV Toolnix to remove the subtitle tracks after the fact (transcoding with Handbrake also allows that option).
In MakeMKV, if you click on the little triangle next to each title in the left hand menu, it will expand to show you the individual tracks for audio, video, and subtitles. Uncheck the ones you do not want to capture.
There are also ways to set your profile to ignore subtitles, but you're into the Advanced features at that point. Important if you're ripping dozens of disks per week, not so much if it's one or two a day.
doncht
That one is really tricky. I didn't even know that option existed. Thanks!if you click on the little triangle next to each title in the left hand menu,
