Chasing Amy
Chasing Amy
I am getting scrambled video for two particular titles on the Blu-Ray of Chasing Amy. The rest of the disc rips fine, except for these two featurettes. These two featurettes also happen to be the only newly created special features for the disc. The movie and the older special features convert fine. I've been ripping a bunch of Blu-Rays lately and have not encountered this problem anywhere else. i do not get any type of error code in the log, and I haven't been able to find a solution anywhere else. I don't know if it's a problem with the disc's protection or something else.
Thanks.
Thanks.
Re: Chasing Amy
Just to let everyone know, I am still having this problem. It's weird; I've ripped at least 15-20 blu-rays so far and this is the ONLY one that has this problem, and it's only for these two specific titles. I've tried to do a backup of this disc and try to manually convert the m2ts files, but I still have the same problem. The disc is protected with AACS v19, but I don't think that's the problem. If it helps, this is what the scrambling looks like, I can still hear the audio.
Re: Chasing Amy
Have you enabled debugging (Settings, General), as outlined in the link below? Anything showing up in the log?
Generally speaking, if MakeMKV encounters a version of BD+ that it doesn't know about, it will generate a file that should be forwarded to svq@makemkv.com , and it will give you the path to that file in the debugging messages.
Re: Chasing Amy
Thank you for responding. Like I said earlier, I enabled the log and did not see any type of error code. I'll attach it here. It is a strange phenomenon as I said, since I have ripped many blu-rays so far and have not encountered this problem anywhere else. I'll try that email address. Thank you again.Woodstock wrote:Have you enabled debugging (Settings, General), as outlined in the link below? Anything showing up in the log?
- MakeMKV_log.txt
- (6.66 KiB) Downloaded 765 times
Re: Chasing Amy
Looks more like a decoder issue than anything to do with MakeMKV.
Try playing the file back using different software, I always have the best luck with SMplayer.
Smithcraft
Re: Chasing Amy
If you scan the file with MediaInfo, what is the video codec(you can paste the whole video section if you aren't sure)?
SC
SC
setarip_old
Re: Chasing Amy
Return the disc to the place of purchase in exchange for a new replacement...I haven't been able to find a solution anywhere else.
Re: Chasing Amy
Thanks everyone. As suggested, I opened the disc in a different player (VLC) and I still have the same problem with these titles. I downloaded Aurora Blu-Ray player and these titles were less scrambled, but still not correctly playing.
I also don't think the disc is defective because these titles did work on a real blu-ray player. There must be some kind of advanced/unknown decryption on these titles, it's just very strange I haven't encountered it on any other disc.
The codec is Windows Media Video VC1 (VC-1). I don't think this is the problem, because the titles on the same disc that work correctly have the same codec.Smithcraft wrote:If you scan the file with MediaInfo, what is the video codec(you can paste the whole video section if you aren't sure)?
SC
Re: Chasing Amy
Does it use progressive or interlaced coding? When we're talking about VC-1, it matters.fearltd wrote:The codec is Windows Media Video VC1 (VC-1). I don't think this is the problem, because the titles on the same disc that work correctly have the same codec.
Re: Chasing Amy
I think this is the problem. I looked it up, and I believe that these titles are interlaced while the others are progressive, which explain why they work and these do not. I know know if there's a definitive easy way to deal with these files. Thank you for your help.Romansh wrote:Does it use progressive or interlaced coding? When we're talking about VC-1, it matters.fearltd wrote:The codec is Windows Media Video VC1 (VC-1). I don't think this is the problem, because the titles on the same disc that work correctly have the same codec.
Re: Chasing Amy
With any luck, VLC 2.1 will include interlaced VC-1 support.
You can download the first release candidate here:
http://www.jbkempf.com/blog/post/2013/VLC-2.1.0-rc1
