I've just started processing blu rays through MakeMKV. First attempt was Flight. Processed and played without a hitch. Then I processed all the Lord of the Rings Extended Edition Blu ray discs using MakeMKV beta v1.8.4 64bit. All exhibit stuttering. Then I processed The Bourne Ultimatum with no problems at playback. All movies are being played over a network from a DLNA server (Serviio) to a DLNA client (Sony BDP-S570). At first I thought it was a bandwidth issue. But now I don't believe that's the problem. I checked the data rate on the S570 for all movies. They all max out at about 30mbs with Ultimatum probably having the highest average rate. Any ideas why stuttering is limited to the LOTR discs?
Lord of the Rings from Blu Ray stutters
angelgraves13
Re: Lord of the Rings from Blu Ray stutters
Lord of the Rings play fine for me...took me awhile to make them too since I cut then joined Parts 1 and 2 of each film to make one file for each. They all play fine. I suspect your network can't handle the load.
nestorquay
What networking gear and player are you using?
