Big Bang Theory 5th Season Disc 2
Puggie721
#1 Post by Puggie721 » Wed Sep 04, 2013 10:46 am
File 00055.mpls was added as title #0
File 00054.mpls was added as title #1
File 00053.mpls was added as title #2
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00041.m2ts' at offset '0'
Goes on like this for several minutes and only saves 1 episode. Crushed... :cry: Successfully done on previous seasons.
Re: Big Bang Theory 5th Season Disc 2
#2 Post by Woodstock » Wed Sep 04, 2013 1:41 pm
The operating system is telling MakeMKV that it can't read parts of the disk. The fact that it read others usually means that the drive itself is OK, but you might want to clean it anyway.
Steps to take start with cleaning the disk in question. If it is a newly-purchased disk, exchanging it for another is an option.
On older disks, sometimes waxing them will give you a good enough surface to rip, But be careful of the wax you use; some use solvents that can attack the disk surface, and make matters worse. You want one that is compatible with plastics, so no alcohol or petroleum allowed.
Puggie721
#3 Post by Puggie721 » Wed Sep 04, 2013 8:44 pm
Hmm i see. I will look into that thank you
