Evil Dead 2 Blu-ray (Studio Canal UK Box set)
8bitheart
Post by 8bitheart »
I wonder if anyone could help.
I recently purchased The Evil Dead Trilogy released by Studio Canal in the UK.
I have sucessfully ripped and converted discs 1 & 3 of this set, but disc 2 - Evil Dead 2 - just will not be read by the drive.
Here's the log:
Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00d" opened in OS access mode.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
DEBUG: Code 0 at "KtD$<5KR<dL%Y'(}N:121264303
DEBUG: Code 0 at "KtD$<5KR<dL%Y'(}N:121262394
DEBUG: Code 1 at "KtD$<5KR<dL%Y'(}N:121262394
DEBUG: Code 2 at "KtD$<5KR<dL%Y'(}N:121262394
DEBUG: Code 3 at "KtD$<5KR<dL%Y'(}N:121262394
DEBUG: Code 4 at "KtD$<5KR<dL%Y'(}N:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E3C1C6F10620BD525FBA3D40364FB2161A to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
DEBUG: Code 0 at y?+DtD<!k=={NB{TR:213130743
DEBUG: Code 0 at "KtD$<5KR<dL%Y'(}N:29395034
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00260C268DE45182B362658F4F5FC43D811 to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E165A64716679552769458B3EA61BF64E1 to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..036CD5975331B3EA1E73FC786B74648A271 to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..060167DFC30A2F5A231D3B2F9CCFB106A70 to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D6CFEFC360F91830F0A63BA26C1566A43E to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..093B150984EFE355F78FDE74C567DF1EA0F to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01470EE479AB813533AA1417FCF7A6278EB to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E68D6477BCCD1BEA53E82B716207C96E36 to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00E48E1DF5DB202B84A9BC1B0B29207F87F to device 'IoKit:IOBDServices:1a3e638463b72a7d:TSSTcorp BDDVDW SE-506BB TS00'
Highest AACS version is v36 , MKB saved as /Users/david/.MakeMKV/MKB_v36_8294020.tgz
DEBUG: Code 0 at tdR5BlZ[=;8;qV;n:121263544
DEBUG: Code 0 at tdR5BlZ[=;8;qV;n:121265223
MakeMKV believes the disc is using AACS v34.
The disc itself is brand new, plays perfectly fine when viewed using the drive, but for some reason, MakeMKV can't seem to register it.
I am using the most current version of MakeMKV and I am using OSx 10.8.4.
any ideas as to why i'm getting this error and how to fix it?
Re: Evil Dead 2 Blu-ray (Studio Canal UK Box set)
The key seems to be this:
MakeMKV asked the operating system to read the disk, the OS said it couldn't. Everything else cascades from that. The player software can elect to ignore read errors, or not. Ripping software usually cannot ignore them. MakeMKV has to be able to read certain parts of the disk to determine how to proceed with the decryption.
8bitheart
Post by 8bitheart »
Is there any reason why the OS can't read this disc, but could read the other 2 which are from the same set, so I assumed would have been authored a similar way (and both have been read and ripped without any problem?)
Is there anything I can do to 'fix' this problem?
One possibility is always to clean the disk, even if it is new. I've had more than one disk set arrive "off the pegs", rattling around the packaging, including one this past week.
For DVDs, the scratches were superficial enough that both disks ripped without additional work, but my procedure when it fails is to try a different drive (especially with DVDs, since DVD and BD players use different lasers, and sometimes a DVD is fine in a DVD drive, but not in a BD), then to "Pledge it" (wax it with Pledge furniture wax), and return it for exchange if that doesn't work.
Lots of things can go wrong in the manufacturing process, so the disk could be "perfectly defective", i.e., no visible defects, but the bits themselves were wrong.
