I've tried ripping multiple times and wiping the disk off. No luck, it always ends in failure.
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745434112, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745501696, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745507840, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745513984, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745520128, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745526272, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745532416, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745538560, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745544704, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745550848, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745556992, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745563136, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745569280, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745575424, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 26745581568, attempting to work around
Hansel and Gretel Witch Hunters
crowfax
Re: Hansel and Gretel Witch Hunters
damaged or dirty disc.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
