Crashing/ Freezing mid-rip
thedigitalhobo
Post by thedigitalhobo » Mon Aug 26, 2013 4:32 pm
I've been having some problems for a while now. First they were intermittent, but now it seems I've got them full time.
My previous drive (Asus rebranded lite-on, i believe) was failing about 50% of the time. Seems like the OS just "lost" the drive and I'd have to do a restart to get it back. I thought it might have been because it had some "green" feature that was trying to save energy or something.
Got a new drive. LG UH12NS30, and my first to rips failed about half way. I know (from searching) there's a lot of people who are having their optical drives just disappear in Win 7, but I haven't found a solution. I think I'm in that camp.
Any suggestions?
Debug log started at Mon Aug 26 05:04:46 2013 , written by MakeMKV v1.8.4 win(x64-release)
001005:0000 MakeMKV v1.8.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Corey/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEFgACATRPNTA0MTkgAQkAAAEKAAw=
DCE=I6LwdpEZhj2iWZquw+ktrPLzgVEem0F1GyQHBrU7tcSDW+NL3N9aDtr2ZPWpS7KzBKRxH7klcjO517ZkXoIAyNefYnu4wVijcRusXKdDxiuk2d5FwRkbQbEzfVxRbt2Sd/MlSzuEQV+BJCQiccmkvjaaO4kU4aDt2Q==
DCE=XEj+GT7QWb2Mu7FgqGjHvFaFkNWNmX9maG98Gk0QO1HfAePLev+zSrpwyirmXdsTlw1cBsk62mVTAqWw5OMyriZL+iqlhTHFrU4IH2vN2NnlXKnytfY2JkmtxHS0L5qmMZ6PjvwSfBtRUOVX13FfQOFt6Tl8gL17ow==
003338:0000 Downloading latest SVQ(s) to C:\Users\Corey/.MakeMKV ...
003317:0000 Loaded 12 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=81487FE5130C2DBF343340B5DA8A4F0CFBAF6F4A
003025:0000 Title #00888.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00013.mpls was added as title #0
003025:0000 Title #00012.mpls has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00300.mpls was added as title #1
003307:0000 File 00205.mpls was added as title #2
003025:0000 Title #00014.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00038.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00045.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00058.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00059.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00060.m2ts was added as title #3
003307:0000 File 00061.m2ts was added as title #4
003307:0000 File 00062.m2ts was added as title #5
003307:0000 File 00063.m2ts was added as title #6
003307:0000 File 00064.m2ts was added as title #7
003307:0000 File 00066.m2ts was added as title #8
003307:0000 File 00067.m2ts was added as title #9
003025:0000 Title #00068.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00069.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00070.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00071.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00072.m2ts was added as title #10
003307:0000 File 00073.m2ts was added as title #11
003025:0000 Title #00074.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00081.m2ts is equal to title 00205.mpls and was skipped
005014:0000 Saving 1 titles into directory G:/
001003:0020 DEBUG: Code 258 at @$.16=RoTz`UlkAq\~2! p|r=:121263521
001003:0020 DEBUG: Code 2147483906 at ,H[9w7UNu=uP,SVm:29393953
002003:0000 Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/BDMV/STREAM/00057.m2ts' at offset '26118979584'
001003:0020 DEBUG: Code 3221225624 at @$.16=RoTz`UlkAq\~2! p|r=:121263521
001003:0020 DEBUG: Code 3221225624 at ,H[9w7UNu=uP,SVm:29393953
002003:0000 Error 'OS error - {Device Busy}
The device is currently busy' occurred while reading '/BDMV/STREAM/00057.m2ts' at offset '26118979584'
001003:0020 DEBUG: Code 0 at AFy-bs<0K1Mru,UE'X0':121262739
001003:0020 DEBUG: Code 0 at (o,v{y,oyN{tFL_**oup:121261888
001003:0020 DEBUG: Code 0 at AFy-bs<0K1Mru,UE'X0':213130743
001003:0020 DEBUG: Code 12753408 at AFy-bs<0K1Mru,UE'X0':29393332
001003:0020 DEBUG: Code 0 at vKB(dGEhkkgO}MEm^zu\*:29398645
Re: Crashing/ Freezing mid-rip
Post by mike admin » Tue Aug 27, 2013 8:09 am
Is this an internal SATA drive? I honestly would blame the cable / connectors.
thedigitalhobo
Post by thedigitalhobo » Tue Aug 27, 2013 4:46 pm
yes, its internal.
I guess I should change the cable and see if thats it.
I also did some searching and found the Upper/Lower filter fix and tried that.
I did manage to get through 5-6 rips last night without any crashing, so that may have been it.
But higher quality cable isn't a bad idea either.
(btw, I noticed you're the admin. should I have posted this in a different forum? My bad!)
