Wolf Children (Korean release): fails silently
choongmin
Post by choongmin »
This is a Korean release of Wolf Children (???????????, ????) blu-ray.
Manufacturer: TSSTcorp
Product: BDDVDW SE-506AB
Revision: TS01
Serial number: R8R46GWC9001KC
Bus encryption flags: 1F
Highest AACS version: 37
Disc Information
Data capacity: 37.78 Gb
Disc type: BD-ROM
Number of layers: 2
Type: Blu-ray
Label: WOLFCHILDREN
Protection: AACS v37
Logs:
MakeMKV v1.8.4 win(x64-release) started
Title #00000.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.mpls was added as title #0
File 00002.mpls was added as title #1
Title #00004.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/Choongmin/Desktop
Failed to save title 1 to file C:/Users/Choongmin/Desktop/Wolf_Children_Blu-ray_Disc_t01.mkv
0 titles saved, 1 failed
Re: Wolf Children (Korean release): fails silently
Please enable debugging (link in my signature below), attempt the rip again, and post the log generated.
choongmin
Post by choongmin »
Here are the logs:
Debug logging enabled, log will be saved as C:\Users\Choongmin/MakeMKV_log.txt
DEBUG: Code 0 at zH6S?E5K85!+n7Kw98h:29398530
DEBUG: Code 0 at zH6S?E5K85!+n7Kw98h:121262417
DEBUG: Code 0 at zH6S?E5K85!+n7Kw98h:121262210
DEBUG: Code 0 at vKB(dGEhkkgO}MEm^zu\*:29398369
DEBUG: Code 0 at vKB(dGEhkkgO}MEm^zu\*:121266925
DEBUG: Code 0 at Fca}T$fvmI`2k!Vs`*=:213130697
DEBUG: Code 0 at Fca}T$fvmI`2k!Vs`*=:121263958
DEBUG: Code 0 at Fca}T$fvmI`2k!Vs`*=:213131801
DEBUG: Code 0 at Fca}T$fvmI`2k!Vs`*=:29397564
DEBUG: Code 0 at 0i!pg~/_9"P,n'w;:213130122
DEBUG: Code 0 at vKB(dGEhkkgO}MEm^zu\*:29398645
DEBUG: Code 0 at u=Y2U\&>hJS4=wQQHa:121266580
DEBUG: Code 0 at u=Y2U\&>hJS4=wQQHa:29399059
choongmin
Post by choongmin »
The full log is here: https://www.dropbox.com/s/i8r4lhm9smn2p ... KV_log.txt
The one I posted earlier was copied from the program log area.
Do I have to post the link to the test dump file too? I sent it to support@makemkv.com 4 days ago.
Post by mike admin »
choongmin wrote:Do I have to post the link to the test dump file too? I sent it to support@makemkv.com 4 days ago.
No, we have your dump. I don't know any more details at the moment though.
choongmin
Post by choongmin »
The new 1.8.5 solved it. Thanks!
