"no FUTs obtained " for "Bus Stop"
Jal_andre
Post by Jal_andre » Fri Aug 16, 2013 11:12 am
The usual Macroblockings in the FOX-BluRays
I have uploaded the dump via Dropbox and sent an email to svq@makemkv.com.
Love your program!!
Thank you for your work
Kind regards
doncht
Re: "no FUTs obtained " for "Bus Stop"
Post by doncht » Sun Aug 18, 2013 5:52 pm
It might be helpful if you can dump some of those logs here. Other users might be able to help you out.
Jal_andre
Post by Jal_andre » Sun Aug 18, 2013 8:31 pm
I?d be glad to help, but
if I understand it right , these files have about 38 MB zipped, and over 100MB unzipped.
So my only contribution from my end can be patience.
Romansh
Post by Romansh » Sun Aug 18, 2013 9:21 pm
Ever heard of Dropbox? ;-)
Post by Woodstock » Mon Aug 19, 2013 2:50 am
Actually, he used dropbox for this... doncht seemed to think the information would be helpful on the forum, which it wouldn't be... since we can't translate the dumps into SVQ files. ;)
Jal_andre
Post by Jal_andre » Mon Aug 19, 2013 6:15 am
Now that`s interesting!
The other Fox_dumps were amazingly quick translated by you.
Where is the difference in this case? Is it mere coincidence?
Does it just takes longer this time? Or have they found the Master-encryption?
