Jack Reacher
Jack Reacher
Tried 2 different disks several times and get the same error's. This is the first disk I've never been able to rip. Assuming its the LG drive based on the error messages but cant find any new firmware etc. Any help would be appreciated.
Saving 1 titles into directory E:/MakeMKV
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7767521280'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7767914496'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7768178688'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7769223168'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7769487360'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7769880576'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7770796032'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7770992640'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7771453440'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7771650048'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7772110848'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7772504064'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7772762112'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7773616128'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7773812736'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7774470144'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7774728192'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7774924800'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7775121408'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7775582208'
Failed to save title 0 to file E:/MakeMKV/Jack_Reacher_t00.mkv
0 titles saved, 1 failed
- MKB_v36_Jack_Reacher.tgz
- (14.88 KiB) Downloaded 609 times
Re: Jack Reacher
disc is damaged or dirty.
Re: Jack Reacher
Both discs are visually perfect. not sure whats going on.
Re: Jack Reacher
If your eyes can see 50gb of 1's and 0's then you're the next level of human evolution.
The message is from your drive, MakeMKV is just passing it on to you, and the message is that your drive can't read the disc.
Re: Jack Reacher
I appreciate the help but really? Cant even escape such comments here either?
Interesting that both disks look great (better than many others I've used) and the only title I've ever had issue with. Wonder if they're just a bad batch?
Lame O.
Lame O.
Re: Jack Reacher
I've also had a couple of these fails with:
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7764768768'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7765555200'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7766605824'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '7770796032'
Nothing that I see refering specifically to "Cannot read medium"
Re: Jack Reacher
adwhite wrote:Nothing that I see refering specifically to "Cannot read medium"
occurred while readingCorrect. And bad batches tend to be shipped to the same store, so it may take a while before you get a good one.Wonder if they're just a bad batch
Re: Jack Reacher
Something helpful and not facetious:
/faq/item/7
Worked for me with a title I was having trouble with. Took longer to rip, but worked.
/faq/item/7
bpwhistler
Re: Jack Reacher
I had the same problem. Tried to rip to MKV and had read errors. Watched movie without difficulty. Tried to do backup of disc...hash check failures...'file corrupt.' Not sure this is a damaged disc. I don't know anything about the tech of ripping movies, but this 'seems' like copy protection to me.
Re: Jack Reacher
Not working on 1.8.10. Tried on LG and Panasonic drives.
