Weird problem
JLWaller
Weird problem
#1 Post by JLWaller » Fri Aug 09, 2013 10:16 pm
I have been using MakeMkv for sometime now. For all of this time it has been using all 6 cores in my system which makes converting from ISOs fast. Recently I have had some major computer problems. I seem to have solved them, but, since then MakeMKV is single core only and I cannot find a way to make use, or be aware of the other 5 cores. I do not know if in the process of fixing my computer issues I may have delete anything necessary for it. I have uninstalled, cleaned up my machine, and reinstalled, with no luck. Any ideas as to what is wrong?? I am running a Windows 8 machine and things worked fine until this past week.
Thanks,
JohnW
JLWaller
Re: Weird problem
#2 Post by JLWaller » Sat Aug 10, 2013 11:10 pm
Well, it seems that Malwarebytes was the culprit. Once I uninstalled it, I got speedy conversions again. It is not my default anti-virus, Windows Defender is, but I do use it when troubleshooting major issues, and I had not uninstalled it once I was done.
John Waller
doncht
Re: Weird problem
#3 Post by doncht » Sun Aug 11, 2013 2:01 pm
That's really interesting. Since MBAB doesn't have real time protection but it only scan your PC when you do it manually. But nice to see this working for you.
NodNarb012
Re: Weird problem
#4 Post by NodNarb012 » Mon Aug 12, 2013 2:42 am
The paid Pro version does have real time protection.
