Copy complete, 0 titles saved, 1 failed
Mk2548
Post by Mk2548 »
I just tried to back up 1990 Bronx Warriors (Shriek Show) but I keep getting the following error message:
"Copy complete, 0 titles saved, 1 failed"
The dvd is playing properly and I have tried it on a different drive but the message is still the same. Here's the rest:
MakeMKV v1.8.4 win(x86-release) started
Title #1 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Complex multiplex encountered - 1 cells and 2772 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #3 was added (1 cell(s), 0:40:01)
Complex multiplex encountered - 1 cells and 418 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #4 was added (1 cell(s), 0:06:01)
Complex multiplex encountered - 1 cells and 224 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #5 was added (1 cell(s), 0:03:13)
Title #7 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Complex multiplex encountered - 11 cells and 5783 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #9 was added (11 cell(s), 1:23:25)
Title #10 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Complex multiplex encountered - 1 cells and 161 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #11 was added (1 cell(s), 0:02:19)
Audio stream #1 looks empty and was skipped
Does anyone what I can do to fix this? Thanks
Re: Copy complete, 0 titles saved, 1 failed
And you're getting now error messages prior to the failure message?
Turn on debugging and re-run the rip. Instructions in my signature. There are a lot of messages that won't display unless you have debugging turned on.
Chances are, the problem is a dirty or scratched disk; DVD players will ignore unreadable sectors if there aren't too many of them in a row, but MakeMKV won't, since it's trying to create an accurate rip.
Mk2548
Post by Mk2548 »
Here's the full message
Debug log started at Sat Aug 10 01:11:37 2013 , written by MakeMKV v1.8.4 win(x86-release)
001005:0000 MakeMKV v1.8.4 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\NX/MakeMKV_log.txt
003025:0000 Title #1 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003024:1000 Complex multiplex encountered - 1 cells and 2772 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #3 was added (1 cell(s), 0:40:01)
003024:1000 Complex multiplex encountered - 1 cells and 418 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #4 was added (1 cell(s), 0:06:01)
003024:1000 Complex multiplex encountered - 1 cells and 224 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #5 was added (1 cell(s), 0:03:13)
003025:0000 Title #7 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 2 at M?CB[P{;TT4BdYei:213137827
003024:1000 Complex multiplex encountered - 11 cells and 5783 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #9 was added (11 cell(s), 1:23:25)
003025:0000 Title #10 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003024:1000 Complex multiplex encountered - 1 cells and 161 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #11 was added (1 cell(s), 0:02:19)
003034:0000 Audio stream #1 looks empty and was skipped
005014:0000 Saving 1 titles into directory C:/Documents and Settings/VB/Desktop
001003:0020 DEBUG: Code 3 at t)kJjKFA*k*gsu*]@,:121265729
001003:0020 DEBUG: Code 0 at t)kJjKFA*k*gsu*]@,:213134607
001003:0020 DEBUG: Code 0 at t)kJjKFA*k*gsu*]@,:29399059
005003:0000 Failed to save title 3 to file C:/Documents and Settings/VB/Desktop/title03.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat Aug 10 01:43:13 2013
