Dialog warns about using AnyDVD HD even on ISO images
mcgroarty
Post by mcgroarty »
MakeMKV warns about speed and compatibility if AnyDVD HD is active when I use MakeMKV. This probably makes sense.
However, it also gives this warning if ripping from an ISO image generated by AnyDVD HD, and even on a Mac. If it's still applicable in this case, perhaps it would make sense to tailor the message when the input source is an image file rather than a device. If it's not applicable, maybe it shouldn't be displayed in these cases?
Re: Dialog warns about using AnyDVD HD even on ISO images
But, if the "image" has been created by something that can corrupt the data stream in real time, shouldn't the "image" (which isn't really an image, if it contains a fingerprint of the program that created it) be considered potentially just as corrupt?
