Unable to rip the US BD version of The Pagemaster released on 6Aug13. Log as follows:
MakeMKV v1.8.4 darwin(x86-release) started
Optical drive "DVD+R-DL TSSTcorp CDDVDW SH-S203N LA00" opened in DASPI v1.3 mode.
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHF" opened in DASPI v1.3 mode.
Optical drive "BD-RE PIONEER BD-RW BDR-206 1.56" opened in DASPI v1.3 mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH14NS40 1.00" opened in DASPI v1.3 mode.
Optical drive "BD-RE PIONEER BD-RW BDR-208D 1.10" opened in DASPI v1.3 mode.
Downloading latest SVQ(s) to /Users/jrwalker4/Desktop/Rips ...
Loaded 230 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /Users/jrwalker4/Desktop/Rips/dump_The_Pagemaster_98A397A7E6E88E39.tgz
BD+ code processed but no FUTs were obtained, errors may follow
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00300.mpls was added as title #0
Title #00012.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #1
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01759.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01760.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01761.m2ts was added as title #2
Title #00021.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/Drobo/Rips/The Pagemaster
Failed to save title 1 to file /Volumes/Drobo/Rips/The Pagemaster/The_Pagemaster_t01.mkv
0 titles saved, 1 failed
BD+ Dump file "dump_The_Pagemaster_98A397A7E6E88E39.tgz" posted to my server:
[url hidden]
The Pagemaster (US 6Aug13 BD release)
Re: The Pagemaster (US 6Aug13 BD release)
SVQ updated, thanks for reporting.
Jon Walker
Not a problem. Confirm SVQ worked. Am in the process of proofing final iTunes managed ?TV custom file transcode. Everything looking good. As always, thanks for the quick response.mike admin wrote: SVQ updated, thanks for reporting.
