Greetings,
I'm unable to rip any Blu-ray discs with MakeMKV v1.8.4. I mostly get Scsi errors continuously. Discs that ripped with earlier versions now fail. I have uninstalled and installed again on two machines (HP and Alienware) - same errors. I've tried about 10 discs, but no good result.
For the HP:
Product: BDDVDRW CT10L
Revision: YC07
Serial number: KZ697OB0800
Firmware date: 2008-09-12 12:34:56
Highest AACS version: 19
AACS v17 for the disc itself.
I think there is a firmware update for the HP drive, but I haven't determined how to get it or apply it yet. The Alienware is a newer 17.
Suggestions?
Thanks.
'The Wolfman' (and other) rips fails
- MakeMKV_log (Wolfman).txt
- Log for The Wolfman
- (51.87 KiB) Downloaded 393 times
- Contact:
Re: 'The Wolfman' (and other) rips fails
002003:0000 Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CT10L YC07' at offset '24843909120'Re: 'The Wolfman' (and other) rips fails
I thought that too, but same errors on two different PCs, set up very differently. Plus, every disc I try fails, not just this one. Many of these same discs ripped just fine with earlier versions of MakeMKV. Regardless, I ordered a new external BD drive. I'll post what happens when that arrives.
