Error: "The volume key is unknown for this disc"
wolrah
#1 Post by wolrah » Wed Jan 27, 2010 3:12 am
I am trying to use MakeMKV on an image I just extracted using Linux on my PS3. The command used on the PS3 follows:
dd if=/dev/cdrom of=/mnt/media/Unsorted/TheFugitive.iso bs=128k
This command has been listed on a number of web sites as the correct way to rip an encrypted base image with the PS3.
Whenever I try to open this image in MakeMKV, I get the following in my log window:
MakeMKV v1.4.11 beta darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/wolrah/MakeMKV_log.txt
DEBUG: Code 4294967295 at 5#n<HAC}5![% >~^"b;N#NZ'?,/:213135527
Cannot obtain exclusive access for optical drive "MATSHITA DVD-R UJ-867 HA13" - disc reading will likely fail. You may want to eject and reload the disc while makemkv is running.
DEBUG: Code 0 at 5#n<HAC}5![% >~^"b;N#NZ'?,/:121265039
DEBUG: Code 4026532549 at +Ubw[k&&.Wx/vp:29394735
DEBUG: Code 4026532549 at ^Dhxvkb&1(cWiUvE:121262992
DEBUG: Code 0 at ^Dhxvkb&1(cWiUvE:121262762
DEBUG: Code 0 at 5^1,0jMTJ#|QGd(:29394321
The program can't find any usable optical drives.
DEBUG: Code 0 at _Rh5sl#L})]vDwcMOkS:121263015
DEBUG: Code 0 at _Rh5sl#L})]vDwcMOkS:213132721
Everything I've read says all the currently known AACS keys are included with the software. I have also downloaded the file needed for BD+ and told MakeMKV where to find it.
Using the latest Mac version downloaded about an hour ago on a MacbookPro4,1 running OS X 10.6.2. The movie in question is The Fugitive. I am currently running the dd step on Beerfest as well to give that one a try.
edit - Results on Windows 7 x64:
MakeMKV v1.4.11 beta win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\wolrah/MakeMKV_log.txt
DEBUG: Code 32 at Xsq%HKKF!b4w;]==Av-50{.h_:213130099
Failed to open file Z:/Unsorted/TheFugitive.iso
setarip_old
Re: Error: "The volume key is unknown for this disc"
#2 Post by setarip_old » Wed Jan 27, 2010 5:37 am
You might have better feedback if you post this in the Linux sub-forum here.
I had no trouble using the Windows version of MakeMKV with "The Fugitive" BluRay (US)
1) Have you used this PS3/Linux procedure successfully before?
2) Have you tried mounting and playing the .ISO image file that you created?
3) Regarding AACS and BD+ - MakeMKV doesn't have to be directed to them (Everything is self-contained)
