Sunshine Can't open BR times out
dzl13
Post by dzl13 »
Tried over and over to no avail. Here is the error code:
Loaded 231 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00011.mpls(1) has length of 293 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00012.mpls(1) has length of 200 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00059.mpls has length of 547 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00002.mpls has length of 68 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
DEBUG: Code 100860416 at (o,v{y,oyN{tFL_**oup:213134009
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '748222464'
DEBUG: Code 0 at T2@\mNm1*`r5LO0^J:121263659
DEBUG: Code 16 at T2@\mNm1*`r5LO0^J:29397127
DEBUG: Code 16 at %\T;nkNlV#CJ?B&[:121262233
DEBUG: Code 0 at 5_3".8YpfTg)8;E:121268443
DEBUG: Code 0 at ~l.,#*@=07J["Mg6:29406442
Title #00001.mpls was skipped
Title #00070.mpls has length of 8 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00069.mpls has length of 8 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00038.mpls has length of 425 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00050.mpls has length of 489 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
DEBUG: Code 0 at (o,v{y,oyN{tFL_**oup:121266258
After this last line it will sit and run for 10 minutes and then revert back to the disk load page.
Any suggestions?
crowfax
Re: Sunshine Can't open BR times out
Post by crowfax »
Your drive is telling you it can't read the disk. This is the route cause of your difficulty.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
dzl13
Post by dzl13 »
crowfax wrote:Your drive is telling you it can't read the disk. This is the route cause of your difficulty.
So its the BR drive then? I'd assume there are no workarounds for this then?
Not necessarily the drive, but it is one of the possibilities. More likely is scratches on the disk that make it so the drive can't see the sectors it is trying to find, dirt doing the same thing, or a badly-mastered disk.
First step is cleaning the disk in question, and maybe waxing it (I use Pledge furniture polish to do both at once).
doncht
Post by doncht »
Number 1 probable cause for this is a damaged or dirty disk. Have you tried another one for isolation purposes yet?
briansemerick
Post by briansemerick »
I know this is a decade bump, but I just wanted to say I had the same issue, only on this disc. I think there's something screwy with this bluray.
