"Output Folder" dialog not visible when run as non-admin
enigma3319
Post by enigma3319 » Fri Aug 02, 2013 6:20 pm
Reporting bug for Windows 7 (May be a general bug when not running the app as Administrator)
/images/sshot-s2-web.png
The "Output Folder" dialog and the "MakeMKV" button in the right-hand panel are not there when MakeMKV is not run in Adminstrator Mode.
My install on another XP box didn't require "Run as Administrator" to get the those two components available in the UI.
MakeMKV workflow is kinda annoying without the Output Folder dialog (you have to keep a separate Windows Explorer window open to handle the mkdir and move file stuff).
The disappearing boxes would be hard to troubleshoot for novice. Can you at least grey out those two UI components and provide a tooltip saying something like "These features only available when run as a user with Windows Administrator Privileges"
Love the app. Keep up the nice work.
doncht
Re: "Output Folder" dialog not visible when run as non-admin
Post by doncht » Sat Aug 03, 2013 5:10 pm
Try setting the Default Destination to "SemiAuto". Hopefully, it will make a difference.
