Registration key for 1.8.4?
kakkalla
#1 Post by kakkalla » Thu Aug 01, 2013 10:49 am
I just downloaded this version and am told that the key is too old. I have gone to this post:
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
but the key is valid only till the end of July 31.
It is now 1 August where I am so is there a key available for version 1.8.4?
Thank you.
matt198t
Re: Registration key for 1.8.4?
#2 Post by matt198t » Thu Aug 01, 2013 2:55 pm
same problem
crowfax
#3 Post by crowfax » Thu Aug 01, 2013 3:41 pm
You can buy a key here:
www.makemkv.com/buy/
Or wait for the beta key to be upgraded. If you can't live without the program for a few days, I'd suggest perhaps you should buy the key.
jsmithv
#4 Post by jsmithv » Thu Aug 01, 2013 4:44 pm
ditto...
thedigitalhobo
#5 Post by thedigitalhobo » Fri Aug 02, 2013 1:55 am
maybe change the date on your PC until a new one is posted?
matt198t
#6 Post by matt198t » Fri Aug 02, 2013 4:37 am
doesn't work
liamgunslinger
#7 Post by liamgunslinger » Fri Aug 02, 2013 5:42 am
same
romwarrior
#8 Post by romwarrior » Fri Aug 02, 2013 3:53 pm
New key is up...
kakkalla
#9 Post by kakkalla » Fri Aug 02, 2013 3:55 pm
THANK YOU!
djkenishii
#10 Post by djkenishii » Mon Sep 02, 2013 8:56 am
where can I get the new key?
I am using 1.8.4 under the about > it says I still have until 12 sept but when I try to use it says expired. I double checked my system clock is correct. uninstalled , reinstalled > same issue. help...
#11 Post by Woodstock » Mon Sep 02, 2013 4:46 pm
The link shown in the first post is always kept up with the current key.
