Registration key for 1.8.4?
kakkalla
Post by kakkalla »
I just downloaded this version and am told that the key is too old. I have gone to this post:
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
but the key is valid only till the end of July 31.
It is now 1 August where I am so is there a key available for version 1.8.4?
Thank you.
matt198t
Re: Registration key for 1.8.4?
Post by matt198t »
same problem
crowfax
Post by crowfax »
You can buy a key here:
www.makemkv.com/buy/
Or wait for the beta key to be upgraded. If you can't live without the program for a few days, I'd suggest perhaps you should buy the key.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
jsmithv
Post by jsmithv »
ditto...
thedigitalhobo
Post by thedigitalhobo »
maybe change the date on your PC until a new one is posted?
matt198t
Post by matt198t »
doesn't work
liamgunslinger
Post by liamgunslinger »
same
romwarrior
Post by romwarrior »
New key is up...
kakkalla
Post by kakkalla »
THANK YOU!
djkenishii
Post by djkenishii »
where can I get the new key?
I am using 1.8.4 under the about > it says I still have until 12 sept but when I try to use it says expired. I double checked my system clock is correct. uninstalled , reinstalled > same issue. help...
The link shown in the first post is always kept up with the current key.
