Registration key
tjirbis
Registration key
Post by tjirbis »
My version og Makemkv is prompting this application version is too old. Please download latest version or enter registration key.
Where do i get a registration key?
crowfax
Re: Registration key
Post by crowfax »
If you want to buy one, you can do it here and you'll never see that message again:
http://makemkv.com/buy/
If you want to have to enter a new key every 30 days and not show your support for the program, you can get the free key here:
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
crowfax
Post by crowfax »
Buy a key here which never expires:
/buy/
Or enter the free key here which does expire:
henrylynn
Post by henrylynn »
OK, I just purchased a registration key because I like the software and want to support the developer. But, I've tried to enter the registration key 3 times and each time I get the message that it is not valid. What do I do next?
Smithcraft
Post by Smithcraft »
crowfax
Post by crowfax »
Make sure you're copying the whole key and it's not getting cut short.
cesmkv
Post by cesmkv »
I like the program also but $50 ? that's awfully steep
Smithcraft
That's $50 for life. As in every time the studios don't want you to be able to use your media the way you want, and MakeMKV gets updated to handle the new DRM schemes.
Of course you can use the free key and if it expires while Mike is off on vacation and doesn't update it, then you're out of luck, or try AnyDVD HD for the free trial period of 30 days.
SC
henrylynn
Post by henrylynn »
I tried the key again the next day and it worked. Thanks for responding.
peto11
Post by peto11 »
If it is $50 to buy, why does it translate to $A71.30 ? and you thought $50 was steep
Smithcraft
Outside of the US, I believe it is 50 Euros.
SC
