Unable to save to NFS share
michaudg
#1 Post by michaudg » Fri Jul 19, 2013 5:24 pm
For some time, it is impossible for me to save MKV to a NFS share. It worked well before. I tested the backup of an audio CD to the NFS share with Sound Juicer and it works well. So, i don't think that is my share.
Tested with MakeMKV 1.8.3 and 1.8.4.
On ArchLinux, Kernel 3.9.9 64bits.
Someone would have a possible solution for that?
Thanks.
austingrd
Re: Unable to save to NFS share
#2 Post by austingrd » Sun Jul 21, 2013 1:17 pm
This one is a tough one. Is there any error message when you're trying to do this? Additionally, was there something modified on your box prior to getting this issue?
Mistakes are learning tools. Image
