Terminator 2
kmnjokpa
Terminator 2
Post by kmnjokpa »
Sorry if this issue has been resolved elsewhere, but I didn't find a resolution in my search. I have been unsuccessful creating a copy of any of the 3 versions of Terminator 2 Skynet Edition (Region A, I believe). Each time a file is created, but the video plays like stop motion & is not in sync (a couple seconds off) with the audio.
I am using the 1.8.3 win x64 makemkv version. Playback is on ArcSoft Total Media Extreme.
So far, about 40 other blu-rays have been successful (in copy & playback).
The log is below:
MakeMKV v1.8.3 win(x64-release) started
File 00016.mpls was added as title #0
Title #00137.mpls has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00018.mpls was added as title #1
File 00019.mpls was added as title #2
Title #00080.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00017.mpls was added as title #3
Title 00100.mpls is equal to title 00017.mpls and was skipped
Title #00139.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00156.mpls was added as title #4
Title 00020.mpls is equal to title 00017.mpls and was skipped
Title #00001.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.m2ts was added as title #5
Title #00005.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #6
Title #00007.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #7
Title #00010.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00013.m2ts was added as title #8
File 00014.m2ts was added as title #9
File 00015.m2ts was added as title #10
File 00016.m2ts was added as title #11
Title #00017.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00018.m2ts was added as title #12
Title #00019.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00020.m2ts was added as title #13
Title #00021.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00022.m2ts was added as title #14
File 00023.m2ts was added as title #15
File 00024.m2ts was added as title #16
Title #00025.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00026.m2ts was added as title #17
Title #00027.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00030.m2ts was added as title #18
File 00031.m2ts was added as title #19
File 00032.m2ts was added as title #20
Title #00033.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00136.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00142.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00146.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00157.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00159.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00160.m2ts has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00161.m2ts was added as title #21
File 00162.m2ts was added as title #22
Title #00164.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00181.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00182.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00183.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00188.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00190.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00191.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00192.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00193.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00194.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00195.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00196.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00197.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00198.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00199.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00201.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00202.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00203.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00204.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00206.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00207.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00208.m2ts was added as title #23
Title #00209.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00210.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00211.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00212.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00213.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00214.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00215.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00216.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00217.m2ts was added as title #24
Title #00218.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00219.m2ts was added as title #25
Title #00220.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00221.m2ts was added as title #26
File 00224.m2ts was added as title #27
Title #00225.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00226.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00227.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00228.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00229.m2ts was added as title #28
Title #00230.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00241.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00242.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00243.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00244.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00245.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00246.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00247.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00248.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00249.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00250.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00251.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00252.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00253.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00254.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00255.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00256.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00257.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00258.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00259.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00260.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00261.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00262.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00263.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00264.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00265.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00266.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00267.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00268.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00269.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00270.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00271.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00272.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00273.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00274.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00275.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00276.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00277.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00278.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00279.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00280.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00281.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00282.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00283.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00284.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00285.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00286.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00287.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00288.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00289.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00290.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00291.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00294.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory F:/Z MOVIES/Blu Ray
Forced subtitles track #2 turned out to be empty and was removed from output file
1 titles saved
Thanks for any help.
austingrd
Re: Terminator 2
Post by austingrd »
This could possibly just be a bad disk. Have you tried other ones just to be sure?
Mistakes are learning tools. Image
Smithcraft
Re: Terminator 2
Post by Smithcraft »
I bought this some time ago, and never had any issue.
So either they remastered it to be a hassle, or it might be a bad disc.
SC
