Why is MakeMKV making a WinRAR archive?
When I rip something it creates one, files that say driveatt.dat and MKB_RO.
Re: Why is MakeMKV making a WinRAR archive?
This is actually a new feature in 1.8.0. It is saving a version of each MKB it encounters. It helps in future troubleshooting. if you would check the file size, they are just pretty small and you can probably go ahead and just ignore it. It doesn't hurt to be prepared, you might use it in the future.
Mistakes are learning tools.
